Mean Green Posted December 1, 2012 Share Posted December 1, 2012 I had my clutch replaced about 9 months ago as I could not select any gear. With the engine switched off it would select all gears no problem, but with the engine running it would not select anything - with a really hard push an a lot of crunching it could be forced into a gear - so I had the clutch replaced. It has started happening again - clutch pedal feels normal, but I cannot get a gear with the engine running. Help!! Quote Link to comment Share on other sites More sharing options...
western Posted December 1, 2012 Share Posted December 1, 2012 has the master cylinder pushrod been adjusted, always worth checking after a clutch or master cylinder change. Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 1, 2012 Share Posted December 1, 2012 What was the problem in the first place? Quote Link to comment Share on other sites More sharing options...
Mean Green Posted December 1, 2012 Author Share Posted December 1, 2012 Not sure about the Master cylinder, the garage I used knows Land Rovers and I assume they would have done it - but maybe not!. The original problem was the clutch plate - one of the springs on the clutch plate was completely missing. I will get it back to them and see what they can turn up. Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 1, 2012 Share Posted December 1, 2012 hmmm, unless the missing spring was jamming the clutch plate, I can;t really see that, that would cause siad problems to be honest. Quote Link to comment Share on other sites More sharing options...
Mean Green Posted December 2, 2012 Author Share Posted December 2, 2012 Cheers Mav Will see what the garage turn up. There is also a very bad bang/judder esp in reverse, feels like something slipping so hopefully they can get to the bottom of that too. Quote Link to comment Share on other sites More sharing options...
