greenstream Posted January 9, 2013 Share Posted January 9, 2013 Hi If I wanted to change a R380 from a 300 TDI to V8 configurations how much ould I need to change ? Bellhousing ? Or Bellhousing and pinionshaft ? Thanks Morten Quote Link to comment Share on other sites More sharing options...
Boris113 Posted January 9, 2013 Share Posted January 9, 2013 There are quite a few differences, not just the bellhousing. In short it appears that it's easier to get a different gearbox, unless you are able to strip and rebuild one yourself. This thread should explain it better than I can http://forums.lr4x4.com/index.php?showtopic=79052#entry677394 Harry Quote Link to comment Share on other sites More sharing options...
ashtrans Posted January 9, 2013 Share Posted January 9, 2013 HiIf I wanted to change a R380 from a 300 TDI to V8 configurations how much ould I need to change ? Bellhousing ? Or Bellhousing and pinionshaft ? Thanks Morten Hi, just the pinion and bellhousing assuming you are not changing from long to short stick etc, Dave Quote Link to comment Share on other sites More sharing options...
Ash.Witty Posted January 9, 2013 Share Posted January 9, 2013 Hi I have done this myself. I bought a R380 V8 bellhousing off Ashcroft trans, then used the Td5 release bearing guide, throwout are etc as its the same as v8 stuff. then the tdi Input shaft has a 7/8" end of the shaft which locates into the spiggot bush where as a v8's is 3/4", so you need a V8 spiggot bush borring out from 3/4" to 7/8" to fit the shaft, it will end up with about 1mm wall thickness but mine is holding up fine. use all v8 clutch gear. I did this to my 300 Tdi 110 to put a v8 in and haven't had any problems even with the thin spiggot bush. hope this helps Ash Quote Link to comment Share on other sites More sharing options...
greenstream Posted January 9, 2013 Author Share Posted January 9, 2013 Thanks all of you, this makes life a little easier Off topic - Dave parcel with outputshaft arrived today. Cheers Morten Quote Link to comment Share on other sites More sharing options...
