Jyodaiam Posted February 1, 2013 Share Posted February 1, 2013 Setting off home yesterday the heavens opened so turned on the wipers. Problem was that they moved across the screen but wouldn't return! Any thoughts please, I can't cope for too long with the manual bailing twine return optional extra. Many thanks Quote Link to comment Share on other sites More sharing options...
neonovice Posted February 1, 2013 Share Posted February 1, 2013 The motor runs a rod like cable type thingmy that connects both wiper arms. The rod like cable type thingmy is behind the dash board. Either the teeth on the motor mechanism or the rod like cable type thingmy will be chewed. Not a nice job. Dashboard out if you are of a luckless disposition like me. Quote Link to comment Share on other sites More sharing options...
western Posted February 1, 2013 Share Posted February 1, 2013 motor runs a drive cable not a rod, see page 729 in http://www.retroanaconda.com/landrover/parts_books/110/8_body_electrics_p667-740.pdf to access the motor, remove the grab handle & dash lower left corner [if a RHD vehicle] to remove the motor & drive cable, do the above & remove the wiper blades & arms, otherwise you'll never get the motor/drive cable out of the vehicle Quote Link to comment Share on other sites More sharing options...
Dave W Posted February 1, 2013 Share Posted February 1, 2013 If one or other of the wheel boxes has jammed it'll be because the guide that is supposed to hold the rack (official name for the cable/rod thingy)against the wheel box gear has bent down or worn away. Either way you need to replace the wheel box and possibly the rack. You can replace the rack as described but if the wheel box guide is bent/worn it'll only be a temporary fix. As it's such a PITA to change either of the wheel boxes, I'd suggest changing both of them out while you're there as you'll have to take most of the dashboard out to replace either of them, especially the driver's side one. Quote Link to comment Share on other sites More sharing options...
Jyodaiam Posted February 1, 2013 Author Share Posted February 1, 2013 Dashboard (sorting the radio also) is already out. Thought initially it would be the park switch but does as you're all saying the gears are only turning one way; there was for a while a clicking sound from the wheel box area, would this confirm replacement gears and rod? P.s. while I'm at it, what is the cost in time and cash of putting a third wiper blade? Is it right that I have replace the motor? Ta Quote Link to comment Share on other sites More sharing options...
