L835 Posted March 12, 2013 Share Posted March 12, 2013 Hi, last year the R380 in my 110 died, and was repaced with a Ashworth one. While I was 'in there' I fitted a 130 clutch and X-brake. Sadly I retained the Disco transfer box the 110 came with...... Lately the noise coming from under the floor has reached embarrasing levels! It comprises a metallic 'tinkle' rattle, 'rubbing' squeek and a 'rotary' sound as though something is rubbing on the prop shaft. I have gone through the gears with the T'box in neutral - nothing, and the noises only happens when the 110 is under power, quiet when coasting. I have checked underneath, nothing loose or rubbing, propshaft ujs greased and ok (slight play in one rear but nothing major) which does not explain the bad vibes at 35- 50mph. Although the transfer box only has a slight oil 'weep', old habbits have seen the fluids checked regularly - no major oil losses. I have removed the centre seat and panel, and the noise is definitely from the gear/transfer box area. There is also a slight click/clunk from the T'box when the handbrake is released. So I'm hoping it is the transfer, rather than the gear box (TBH towing and going uphill is very poor with the Disco ratios anyway) so 'does the panel think' its time to swap for a Defender transfer box,or should I be looking elsewhere??? Thanks in advance! Richard Quote Link to comment Share on other sites More sharing options...
TSD Posted March 12, 2013 Share Posted March 12, 2013 Are you sure the pads are correctly fitted in your x-brake? Quote Link to comment Share on other sites More sharing options...
L835 Posted March 12, 2013 Author Share Posted March 12, 2013 Will take the x-brake off and try, but I would be very surprised if it was that due to the variety of noises! Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted March 12, 2013 Share Posted March 12, 2013 I would put good money on it being the xbrake, had mine off yesterday to fit new output shaft seal, refitted it, adjusted the brake to three clicks, and today it's rattling very annoyingly! Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 12, 2013 Share Posted March 12, 2013 If the pads are rattling apparently you can stop it with a bit of silicon. See page 5 of http://www.x-eng.co.uk/Instructions/X-Brake.pdf Quote Link to comment Share on other sites More sharing options...
L835 Posted March 13, 2013 Author Share Posted March 13, 2013 Nope, trial run with x-brake removed, noises still as bad! Next step must be to drop the props and run in gear tomake sure its the tbox.... Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted March 13, 2013 Share Posted March 13, 2013 You said noises only happen under power, I'd remove one prop at a time and go for a drive (in diff lock obviously). If it's the transfer box you should get the noises regardless of which prop is removed. Otherwise it's something to do with the prop/axle that is currently driven if you see what I mean. Quote Link to comment Share on other sites More sharing options...
L835 Posted March 13, 2013 Author Share Posted March 13, 2013 Thanks will try that! Quote Link to comment Share on other sites More sharing options...
Def V8 90 Posted March 19, 2013 Share Posted March 19, 2013 "as though something is rubbing on the prop shaft" Is something maybe rubbing on the propshaft?? Lol In all seriousness I'd start there! Quote Link to comment Share on other sites More sharing options...
L835 Posted March 20, 2013 Author Share Posted March 20, 2013 No, nothing rubbing on the [prop, but have changed the rear UJ, which has largely cured the problem! Can now hear the output bearing 'whooshing' and still have a 'tinkling' like a loose washer sound coming from the t'box. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted March 20, 2013 Share Posted March 20, 2013 Having cured most of the noise, try removing the x brake caliper again! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 20, 2013 Share Posted March 20, 2013 The tinkling noise... does it only happy under load/acceleration? I have a noise that I can only describe as tinkling and I think I've narrowed it down to the release bearing as moving the clutch pedal changes the noise. Quote Link to comment Share on other sites More sharing options...
L835 Posted March 23, 2013 Author Share Posted March 23, 2013 Hi, It happens once the box has warmed up. It isn't a release bearing noise, in any case I fitted a raceway release bearing when I changed the clutch. Quote Link to comment Share on other sites More sharing options...
