Landy-Novice Posted March 23, 2013 Share Posted March 23, 2013 Because the list starts with rear passenger..... what list!?! the picture clearly reads bleed front drivers caliper first.. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted March 23, 2013 Share Posted March 23, 2013 Started withRear passenger Rear drivers Front passenger Last of all front drivers Just checked once the pedal is pumped up if I hold the pressure on it does slowly creep to the floor Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted March 23, 2013 Share Posted March 23, 2013 Started withRear passenger Rear drivers Front passenger Last of all front drivers Just checked once the pedal is pumped up if I hold the pressure on it does slowly creep to the floor which is wrong on a LR. Quote Link to comment Share on other sites More sharing options...
muddy Posted March 23, 2013 Share Posted March 23, 2013 As Sean says clamp each flexi in turn (obviously a no go with braided ones) and if that fails clamp all three together. I sometimes start nearest master, sometimes furthest away, never seems to be an issue. Will. Quote Link to comment Share on other sites More sharing options...
