Igol Posted March 29, 2013 Share Posted March 29, 2013 Simple question, are they swappable? My bottom tailgate hinge looks out of kilter so I think its had it and I've got a spare top hinge off a scrapper so will that replace it? The lower hinge has those 'rivets' on it which seem to be missing on the replacement ones I've googled Quote Link to comment Share on other sites More sharing options...
Nigelw Posted March 29, 2013 Share Posted March 29, 2013 The new ones I got had the plate for the rivets on, can't remember if exactly interchangeable, but I am almost sure they are not. Quote Link to comment Share on other sites More sharing options...
Stevie D Posted March 29, 2013 Share Posted March 29, 2013 From memory they are different top / bottom. Certainly to bottom one has the 'pop' rivet holes - that wouldn't stop me trying - once the rivet heads are removed - use your weapon of choice here - the breakaway center bit is hard so a grinder might be a better option than a drill. It's an easy swap so long as you take the spare wheel off the door first and have somebody / something to support the door. Steve Quote Link to comment Share on other sites More sharing options...
Igol Posted March 29, 2013 Author Share Posted March 29, 2013 Isnt the grinder always the better option? More than happy to give it a go but then I'll be left without a door if it doesn't work so I think I'll head back to the scrappy and grab the lower one. Had the door off when I did the cross member work bench and a jack worked that time with a couple of bits of timber to bulk things up. Quote Link to comment Share on other sites More sharing options...
JeffR Posted March 29, 2013 Share Posted March 29, 2013 Be very very careful, the bolts that go thro the door will shear if they are at all rusty. They will shear in such a manner that, without resorting to extreme violence, you will not be able to pull the hinge out of the door. Been there, done that, got the bad temper and blood loss to prove. Also a Disco rear door is a lot heavier than it looks..... Quote Link to comment Share on other sites More sharing options...
task Posted March 30, 2013 Share Posted March 30, 2013 I took my bottom hinge off and re-pinned it. Quote Link to comment Share on other sites More sharing options...
wnderer Posted April 3, 2013 Share Posted April 3, 2013 I took my bottom hinge off and re-pinned it. where did you get the pins? need to do this on my rear door now, went out after reading the post opened the back door on my disco & the hinge snaped, in my defense I've only had the disco for a few day & this was only the 2nd time I'd opened the rear door Quote Link to comment Share on other sites More sharing options...
Igol Posted April 4, 2013 Author Share Posted April 4, 2013 Or the size of pins you need? I got the top one off the scrapper to experiment with that idea but it ended up in my todo bin. Quote Link to comment Share on other sites More sharing options...
