Simon_CSK Posted May 25, 2013 Share Posted May 25, 2013 I have a D type symbol with a couple of lines through it come up on my dash and are blinking. As a result of this happening the Central locking has stopped working as has the remote opening. Does anybody know what this means. TD5 Disco Diesel on 51 plate. Quote Link to comment Share on other sites More sharing options...
matfield Posted May 25, 2013 Share Posted May 25, 2013 This might help... http://www.diagnostic-world.com/pages/discovery_series_2_dash_lights_207001.cfm Mat Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted May 25, 2013 Author Share Posted May 25, 2013 This might help...http://www.diagnostic-world.com/pages/discovery_series_2_dash_lights_207001.cfm Mat Mat Thanks but it is not a light it is a symbol on the Odometer the the far left of the trip meter. Quote Link to comment Share on other sites More sharing options...
matfield Posted May 25, 2013 Share Posted May 25, 2013 Is it an auto...? If it is check that the selector knob is seated correctly... (put it into neutral and pull it up while pressing the button, it should come up, then sit it back in the hole to line it up and give it a knock with the palm of your hand.) It should sit in, then put it back into park, turn off the ignition and try again. If that doesn't fix it, Put it in Park, get underneith and on the passenger (left) side of the box there is the selector lever, undo the nut (think its a 13mm) and move the selector all the way back and forward (it will click into each selection from P down to 1) then tighten the nut again. See if that helps. If its a manual.............................. put some insulating tape over the odometer. With regards to the central locking..... no idea... maybe just coincidence, but check fuses etc first Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted May 25, 2013 Author Share Posted May 25, 2013 If its a manual.............................. put some insulating tape over the odometer.With regards to the central locking..... no idea... maybe just coincidence, but check fuses etc first Brilliant yes it is a manual. It is going for an MOT on Wednesday will get them to look for clues unless anyone else has any ideas. Quote Link to comment Share on other sites More sharing options...
matfield Posted May 25, 2013 Share Posted May 25, 2013 Sorry That space on the odometer is the indicator for the auto box... Mine was an auto as you may have guessed!. Dunno why it would be lit for a manual but someone far more qualified will be along shortly to correct me Quote Link to comment Share on other sites More sharing options...
matfield Posted May 25, 2013 Share Posted May 25, 2013 Just a thought..... Were you welding recently? Could have fried the BCU? Another stab in the dark but every little helps Quote Link to comment Share on other sites More sharing options...
Meatslicer Posted May 25, 2013 Share Posted May 25, 2013 Over Drive indicator from auto box. If its illuminated in a manual, could be a short Eric Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 26, 2013 Share Posted May 26, 2013 Some sort of problem on the internal network linking the modules would be my guess. Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted May 26, 2013 Author Share Posted May 26, 2013 Just a thought..... Were you welding recently? Could have fried the BCU? Another stab in the dark but every little helps Not welded Since December and now has a new chassis. Over Drive indicator from auto box. If its illuminated in a manual, could be a shortEric Eric What does this look like? I will try and post a photo later. Quote Link to comment Share on other sites More sharing options...
matfield Posted May 26, 2013 Share Posted May 26, 2013 Some sort of problem on the internal network linking the modules would be my guess. Insulating tape.......................... (I'll get my coat!) Quote Link to comment Share on other sites More sharing options...
