NegevLandRover Posted June 14, 2013 Share Posted June 14, 2013 I know this is an old issue and cannot find any recent info. Does any one here know where I can source an ERR 3337 injector for a 3oo TDI EDC - this is the no 4 injector with the electic wire ? TIA Adam Quote Link to comment Share on other sites More sharing options...
western Posted June 14, 2013 Share Posted June 14, 2013 turner engineering http://www.turnerengineering.co.uk/acatalog/info-915.html others say it's an obsolete item & existing one has to be reconditioned Quote Link to comment Share on other sites More sharing options...
steve_a Posted June 15, 2013 Share Posted June 15, 2013 Does the injector just have a pressure transducer to tell the ecu about No 4 firing? If that's the case then it might be possible to just replace with a crank angle sensor or a separate transducer. Anyone have any information, I'll look in Rave at the moment, but I suspect it just says "special".. Edit: An inductive sensor in No 4 injector body monitors needle movement. This forms part of a ’closed loop’ system to control start of injection. The system measures timing, relating the needle movement signal to crank position (determined by flywheel pulses from the engine speed sensor). That's going to be tricky to replace with a secondary sensor I guess. Quote Link to comment Share on other sites More sharing options...
NegevLandRover Posted June 15, 2013 Author Share Posted June 15, 2013 Hi Ralph, I too saw that Turner re-conditions and e-mailed them before posting here and they replied almost imediately saying that they do not re-condition these. Guess I'll have to continue searching and pray that the LR Gods help. Adam Quote Link to comment Share on other sites More sharing options...
NegevLandRover Posted June 15, 2013 Author Share Posted June 15, 2013 Steve, thanks for that. Any chances they have some lying around down under ? I have 2 brothers in your parts that could source and send if they knew where. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 15, 2013 Share Posted June 15, 2013 Do any of the other Rover injectors from engines such as the 2.0 SDI use similar arrangements? I've heard of people fitting 200/300tdi nozzles to the 2.0 L series injectors for more fuelling, so perhaps the injectors are similar enough that they can be used the other way round. Quote Link to comment Share on other sites More sharing options...
Sheffield Posted June 15, 2013 Share Posted June 15, 2013 Are Turners saying that they can not be refurbished, or just that they don't do it? Is the only solution going to be a conversion to the non edc system fitted to manual gearbox Discoverys? I think our edc Doscovery could do with replacement injectors and so this question is of interest to me as well. Quote Link to comment Share on other sites More sharing options...
NegevLandRover Posted June 16, 2013 Author Share Posted June 16, 2013 When I e-mailed them they sent a reply saying that they do not re-furbish. Maybe this is because I am not a UK resident ? Quote Link to comment Share on other sites More sharing options...
NegevLandRover Posted June 16, 2013 Author Share Posted June 16, 2013 Does anyone know the Bosch number for this part ? The LR number is err 3337. Quote Link to comment Share on other sites More sharing options...
