meatymc Posted July 11, 2013 Share Posted July 11, 2013 HiThis is obviously not a unique problem but the threads I've found tend to relate to issues after a new plate has been fitted which doesn't apply in my case. 90 truck cab with 115k on the clock - 6k done since purchased 15 months ago. Have a lot of old receipts but no mention of any work on the clutch but that doesn't mean a lot obviously.There has been no slippage whatsoever just the biting point got lower and lower over a distance of 4/5 miles. Seemed to steady off at around an inch from the floor but reluctant to risk it getting worse to the point can't get into gear so sat on drive - bloody annoying having soft-topped it the weekend before with the weather as it is!No signs of fluid loss anywhere - cylinder still full and master cylinder nice and tight when depressed by hand from above. Clutch pedal set 2 cm too high so lowered to 140mm from floor as per manual but can't see this would have any impact. Breather clear on cylinder cap.Guess we try replacing the fluid although understand this is a pain - any idea what quantity is needed by the way? Then, if no better, replacing the master and/or slave but see comment on master above. Is there any other way of determining the fault source and what else might it be???Any comments appreciated.Cheers Quote Link to comment Share on other sites More sharing options...
Disco1tdi Posted July 11, 2013 Share Posted July 11, 2013 I would suggest that pivot point has punched through the clutch fork.... Quote Link to comment Share on other sites More sharing options...
Disco1tdi Posted July 11, 2013 Share Posted July 11, 2013 http://forums.lr4x4.com/index.php?showtopic=4896 http://forums.lr4x4.com/index.php?showtopic=81684 Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted July 11, 2013 Share Posted July 11, 2013 Sounds hydraulic to me. If there's no fluid loss then there's an internal leak in the master cylinder. Give it a bleed first to see if it helps, in which case air is getting in Quote Link to comment Share on other sites More sharing options...
Gremlin Posted July 11, 2013 Share Posted July 11, 2013 Or the fluid getting really hot. G Quote Link to comment Share on other sites More sharing options...
Lorrick Posted July 11, 2013 Share Posted July 11, 2013 Hi Meatymc I had the same thing and it was the Dual Mass Flywheel was comming lose from the rubber inserts, so as you pushed your foot down on the clutch pedal the whole flywheel was mong away giving the impression of a low pedal, just had mine done, I have a 110 Truck with 180,000 on it. Regards Richard Quote Link to comment Share on other sites More sharing options...
zimmer Posted July 11, 2013 Share Posted July 11, 2013 if it is a tdi chances are it will be the pivot going through the clutch arm did 3 on mine over the years I had it that's 16 years by the way hth Quote Link to comment Share on other sites More sharing options...
jbs Posted July 12, 2013 Share Posted July 12, 2013 Clutch fork John Quote Link to comment Share on other sites More sharing options...
meatymc Posted July 12, 2013 Author Share Posted July 12, 2013 Thanks for all the replies. You'll understand I'll take the easy/simple/cheap options first but given I've nothing to say any work has ever been done on the clutch/box suspect that's where I'll end up. Beyond my limited ability so looks as though could be costly! Quote Link to comment Share on other sites More sharing options...
