o_teunico Posted August 4, 2013 Share Posted August 4, 2013 After seeing Adam´s expedition LR with double alternator, here is the question: can it be done in a Disco or that second alternator will foul the bonnet? Where can I obtain the brackets? (Gwin Lewis has a kit for 300 Tdi, but have not seen it for the 200). Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted August 4, 2013 Share Posted August 4, 2013 Gwyn does do a kit for both 200's defender and disco. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted August 4, 2013 Share Posted August 4, 2013 Yep. I have done it on a 200 disco with a home made bracket. Simples.. Quote Link to comment Share on other sites More sharing options...
o_teunico Posted August 4, 2013 Author Share Posted August 4, 2013 Will contact Gwin then. Thanks! Quote Link to comment Share on other sites More sharing options...
Adam001 Posted August 4, 2013 Share Posted August 4, 2013 If that fails earlier in my build thread it shows the fairly simple bracket and pivot So long as you have reasonable welding skills it's not too hard to fab something up. Quote Link to comment Share on other sites More sharing options...
zardos Posted August 5, 2013 Share Posted August 5, 2013 Check out Gwyn's Ebay store (his web site does not have all the options) http://stores.ebay.co.uk/gwynlewis-4x4/Twin-Alternator-Mounts-/_i.html?_fsub=3850313018&_sid=1002163458&_trksid=p4634.c0.m322 Quote Link to comment Share on other sites More sharing options...
o_teunico Posted August 5, 2013 Author Share Posted August 5, 2013 I will consider both options. Thanks. Quote Link to comment Share on other sites More sharing options...
o_teunico Posted August 5, 2013 Author Share Posted August 5, 2013 It looks simple and effective. Any part # of that Renault alternator you are using? Quote Link to comment Share on other sites More sharing options...
Adam001 Posted August 5, 2013 Share Posted August 5, 2013 I'll grab the number for you tomorrow. I have just re-sprayed my car so can't lift the bonnet! My bracket only works with the air compressor, that's why I went for my own solution. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 5, 2013 Share Posted August 5, 2013 Check out Gwyn's Ebay store (his web site does not have all the options) http://stores.ebay.co.uk/gwynlewis-4x4/Twin-Alternator-Mounts-/_i.html?_fsub=3850313018&_sid=1002163458&_trksid=p4634.c0.m322 Blimey. I've been checking Gwyns site for about two years looking for one of those!!! I didn't know he had more options on ebay! Does that guard plate at the front cover up the hole for checking the timing? Not a big deal I suppose... Quote Link to comment Share on other sites More sharing options...
Adam001 Posted August 6, 2013 Share Posted August 6, 2013 Blimey. I've been checking Gwyns site for about two years looking for one of those!!! I didn't know he had more options on ebay!Does that guard plate at the front cover up the hole for checking the timing? Not a big deal I suppose... It does cover up the timing hole, no dramas really, very easy to tension it up It looks simple and effective.Any part # of that Renault alternator you are using? Part no in photo... I opted to use a 13mm pulley to work with the ac pulley, far superior to the 10mm belts Quote Link to comment Share on other sites More sharing options...
o_teunico Posted August 6, 2013 Author Share Posted August 6, 2013 Thanks! My bracket only works with the air compressor, that's why I went for my own solutionMy bracket only works with the air compressor, that's why I went for my own solution The Disco I will have in the following month also has AC. Quote Link to comment Share on other sites More sharing options...
