stephenburbidge Posted October 10, 2013 Share Posted October 10, 2013 My spare key fob has stopped locking & unlocking the doors remotely on my L332 It works perfectly in the actual lock and starts the vehicle ok. Does anyone know if this can be programmed easily or is it a couple of hundred squid at the dealers? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 10, 2013 Share Posted October 10, 2013 1) Get in and close all doors. Turn ignition on and off quickly and remove the key (all within about 5 seconds).2) Within 30 seconds of turning the ignition off, while holding down the "unlock" button, press the "lock" button three times. Release the "unlock" button. (You may or may not get the confirmation from the door locks.) Holding the key at your head level provides best results as the key sensor is in the side window pillar.3) Repeat for each key you want to initialize within 30 seconds after the last one you initialized (if you have more).4) Right after doing the last key, quickly put the key back in the ignition and turn it on/off again to finalize. From rangerovers.net forum, they tend to know about this sort of thing: http://www.rangerovers.net/forum/6-range-rover-mark-iii-l322/24149-l322-key-not-working.html Quote Link to comment Share on other sites More sharing options...
Rangy35 Posted October 10, 2013 Share Posted October 10, 2013 Yep as above, do the dealers charge for that? On your side of the world. Quote Link to comment Share on other sites More sharing options...
Malachite Posted November 15, 2013 Share Posted November 15, 2013 Hi everyone, this is my first post could anyone tell me how to program a spare one button remote for my classic soft dash? Thank you Paul Quote Link to comment Share on other sites More sharing options...
Emile Robert Posted October 2, 2022 Share Posted October 2, 2022 On 10/10/2013 at 5:33 AM, Rangy35 said: Yep as above, do the dealers charge for that? On your side of the world. My RR dealer in Maine charge $270 to reprogram the key!!!! Quote Link to comment Share on other sites More sharing options...
simonr Posted October 2, 2022 Share Posted October 2, 2022 On 10/10/2013 at 8:33 AM, Bowie69 said: 2) Within 30 seconds of turning the ignition off, while holding down the "unlock" button, press the "lock" button three times. Release the "unlock" button. (You may or may not get the confirmation from the door locks.) Holding the key at your head level provides best results as the key sensor is in the side window pillar. You missed that you have to be rubbing your tummy & patting your head at the same time as doing all this! The last replacement key I had for my RR, a local key place (Timpsons) did it. £100, including the key & fob. 6 years on, still works perfectly. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 2, 2022 Share Posted October 2, 2022 TBH @simonr, I can't even remember writing that Quote Link to comment Share on other sites More sharing options...
