Johannadine Posted October 25, 2013 Author Share Posted October 25, 2013 Cts is coolant temp if it fails then engine runs rich and boggy basic thing to check i also replaced that Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 25, 2013 Share Posted October 25, 2013 What was the fuel psi in the rail ? Ignition on / running ? Quote Link to comment Share on other sites More sharing options...
Nigelw Posted October 25, 2013 Share Posted October 25, 2013 could it be doing this because the Oxygen sensors are out? soooo stressed You need the O2 sensors for the ECU to work correctly, without them the ECU just uses a preset figure as a get you home mode, first thing to do there. And I would double check by unplugging and plugging back in the MAF sensor as to double check the security of connection. Quote Link to comment Share on other sites More sharing options...
