Johannadine Posted October 27, 2013 Share Posted October 27, 2013 Ok we took the wires out put what do we do with the wires that went to the ECU. Thanks Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 27, 2013 Share Posted October 27, 2013 Completely lost me as to what you are asking now ? From what I garther you Are you keeping the Hotwire system at all - ie to control spark Fitting carbs and removing EFI system So If part keeping - you'll need the ECU connected to power fuel pump and coil and switching to ECU You have to swap the HP Pump to a Low pressure pump and fit a suitbale PSI controller to prob about 6-7 PSI or no ECU = everything Hotwire removed - going to carbs and Stand Alone dizzy, which will require a fair rewiring job and again I would question the competance and experience of the "Gargae" doing this work ??? Its like having a puncture and changing the entire axle off a different 4x4 to sort it out ... As I said before I personally think you are digging a bigger and deeper hole .............. Nige Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted October 27, 2013 Share Posted October 27, 2013 Ok, So I've even checked the manual to check I'm not wrong. I have said this in both of your previous threads, so I can only assume I'm not giving you enough information. Disconnect the hotwire loom. That's all the sensors on the engine, road speed sensor, lambda cable, the connection to the vehicle electrical system, the coil and probably a good few earths thrown in as well. Remove it from the vehicle. Check you still have a +12V ignition switched live to the coil (White cable, coil +ve terminal). -ve side goes to distributor. It will make sparks without the ECU present. Replace your fuel pump. You might need a fuel pressure regulator as Nige has said above. I never used one when I ran a V8 on carbs, but then I wasn't using the standard LR fuel pump. Where the fuel pump connected to the hotwire loom, connect a +12V ignition switched live to power it. A convenient cable would be the white cable on the car end of the hotwire to car connector (you have of course unplugged this as the hotwire loom is now on the floor out of the vehicle). I'm not certain of the location - you might need to extend it to reach the cable to the fuel pump. Quote Link to comment Share on other sites More sharing options...
Johannadine Posted October 27, 2013 Author Share Posted October 27, 2013 Ok, So I've even checked the manual to check I'm not wrong. I have said this in both of your previous threads, so I can only assume I'm not giving you enough information. Disconnect the hotwire loom. That's all the sensors on the engine, road speed sensor, lambda cable, the connection to the vehicle electrical system, the coil and probably a good few earths thrown in as well. Remove it from the vehicle. Check you still have a +12V ignition switched live to the coil (White cable, coil +ve terminal). -ve side goes to distributor. It will make sparks without the ECU present. Replace your fuel pump. You might need a fuel pressure regulator as Nige has said above. I never used one when I ran a V8 on carbs, but then I wasn't using the standard LR fuel pump. Where the fuel pump connected to the hotwire loom, connect a +12V ignition switched live to power it. A convenient cable would be the white cable on the car end of the hotwire to car connector (you have of course unplugged this as the hotwire loom is now on the floor out of the vehicle). I'm not certain of the location - you might need to extend it to reach the cable to the fuel pump. what manual can i use to check. Cause im still a bit puzzled cause the coil wire is out with the loom hot wire. Quote Link to comment Share on other sites More sharing options...
Johannadine Posted October 27, 2013 Author Share Posted October 27, 2013 what manual can i use to check. Cause im still a bit puzzled cause the coil wire is out with the loom hot wire. cause there is wires that go to the ECU main plug. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 27, 2013 Share Posted October 27, 2013 ECU PLUG ????That should be out along with the ECU, you should have NO Hotwire harness / Plug ? ECU Loom etc ? Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted October 27, 2013 Share Posted October 27, 2013 what manual can i use to check. Cause im still a bit puzzled cause the coil wire is out with the loom hot wire. If you've removed the EFI loom then you should still have 3 wires on the coil. One coil +ve (white), One coil -ve (no idea what colour) and one HT lead out of the middle to the distributor. Quote Link to comment Share on other sites More sharing options...
Johannadine Posted October 27, 2013 Author Share Posted October 27, 2013 ok. must i put the coil +ve on the ignition positive and coil -ve on the earth thanks so much for you advice and help. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 27, 2013 Share Posted October 27, 2013 Coil negative should be wired to the dizzy, you shouldn't really need to disturb this part of the loom. Quote Link to comment Share on other sites More sharing options...
Johannadine Posted October 28, 2013 Author Share Posted October 28, 2013 There are two wires its a white and blue wire that goes to the ECU and there is a white and green that goes to a connector plug what must i do with the wire that goes to the ECU. Thanks Quote Link to comment Share on other sites More sharing options...
Johannadine Posted October 28, 2013 Author Share Posted October 28, 2013 There are two wires its a white and blue wire that goes to the ECU and there is a white and green that goes to a connector plug what must i do with the wire that goes to the ECU. Thanks The coil -ve goes to the ECU what do i do with that wire. cause the ECU is out . Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 28, 2013 Share Posted October 28, 2013 As above, coil only needs three wires: One ignition lead to top of dizzy Coil negative to dizzy amplifier on side of dizzy Coil positive to ignition live. Quote Link to comment Share on other sites More sharing options...
Johannadine Posted October 28, 2013 Author Share Posted October 28, 2013 As above, coil only needs three wires: One ignition lead to top of dizzy Coil negative to dizzy amplifier on side of dizzy Coil positive to ignition live. how will the tachometer work cause the ecu is out where will that go Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 28, 2013 Share Posted October 28, 2013 Tacho works from the alternator. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted October 28, 2013 Share Posted October 28, 2013 Tacho works from the alternator. On petrol-engines the tacho's usually driven from the ECU or from the coil. Plenty of petrol engines don't have alternators with the "W" terminal used to drive the tacho on clockwork-era Diesels. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 28, 2013 Share Posted October 28, 2013 But on a 3.9 RRC/Disco is driven by the alternator. Quote Link to comment Share on other sites More sharing options...
