Lewis Posted November 21, 2013 Share Posted November 21, 2013 The bulkhead on my 90 is rotten, in particular both top corners. The previous owner was kind enough to supply the usual corner repair panels but the rot on the near side extends past the vent flap hinge, so beyond what the repair section will cover. What are the options here? I've seen the panels that YRM do but they delete the vent, which I'd prefer to keep. http://www.yrmlandrover.com/epages/BT3575.mobile/en_GB/?ObjectPath=/Shops/BT3575/Products/001B Is there an alternative off the shelf solution that does what I need? Or am I resorting to patchwork repair? Many thanks Quote Link to comment Share on other sites More sharing options...
Smego Posted November 21, 2013 Share Posted November 21, 2013 Just cut a small strip of metal to go under the first hinge to fix mine attached to the repair panel Quote Link to comment Share on other sites More sharing options...
Jon White Posted November 21, 2013 Share Posted November 21, 2013 Just cut out the old and replace with new metal. Bulkheads are nice in that it's pretty much all flat panels so very easy to repair as no compound curves. Jon Quote Link to comment Share on other sites More sharing options...
Lewis Posted November 21, 2013 Author Share Posted November 21, 2013 Mines rotten in the only place there is compound curves - around the vent flap, I'll see if I can did out a picture Quote Link to comment Share on other sites More sharing options...
Lewis Posted November 21, 2013 Author Share Posted November 21, 2013 Quote Link to comment Share on other sites More sharing options...
western Posted November 21, 2013 Share Posted November 21, 2013 A mate & myself made these from 2mm sheer steel with seperate end plates a few years ago. photo's in no particular order we made the front part upper inner edge to butt up to the vent flap outer hinge outer edge & the lower inner edge butt to the bonnet hinge outer edge. no sign of any corrosion breaking through yet. Quote Link to comment Share on other sites More sharing options...
Smego Posted November 21, 2013 Share Posted November 21, 2013 My holes were bigger, arse of a job but looks like new now. Quote Link to comment Share on other sites More sharing options...
