Anarchic wipers
More wiper problems (getting a bit boring I am afraid). Completely replaced the wiper motor and park switch in summer. Recently the wipers have taken to having a life of their own that is touchingly inconsistent!
On intermittent instead of one wipe every 20 seconds or so, I get that sometimes but often one stroke, pause, three strokes, pause, one stroke etc. Also when I move from either intermittent or normal use to off it tends to carry on for between two and six extra wipes. Most disconcerting.
I know fear that at some point I will switch them on needing the screen wiped and nothing will happen!
I am guessing the park switch but cannot for the life of me work out what the fault could be. Surely you would expect a park switch to last more than four or five months??? Or is it something else going on?
Any suggestions as to what is happening and how to sort would really be appreciated. Thanks
Malcy
Try replacing the relay, fortunately I've not had this on my Defender. I have similar on other cars.
I've found that if you replace something in a "system" like this then the next weakest component fails...
Cheers,
Mike
No Dumbsey, unfortunately not, you need to have intermittent wipers fitted. You can convert with an additional harness kit and the appropriate switch (you used to be able to buy a genuine harness but no longer, try autosparks perhaps) or google intermittent wiper kits for older cars.
HTH
Mo
Just a quick question, can you get an intermittent wiper relay for a 1985 90?
LR don't supply the wiring section anymore but either make your own up or Autosparks do a subsitute loom http://www.autosparks.co.uk/product_info.php?products_id=5128
in our tech archive is my short write up of how I fitted this system to my '89 110, http://forums.lr4x4.com/index.php?showtopic=927
plus other ways here http://forums.lr4x4.com/index.php?showtopic=20391&page=2
As above.
Buy the Autosparks harness (was LR480 when I bought mine), delay relay (AMR2341) and wiper switch and away you go. All plug & play with no messing about necessary.
Fitted this set-up to my 1986 90 a couple of years ago and it works a treat.
