TheBeastie Posted November 25, 2013 Share Posted November 25, 2013 More wiper problems (getting a bit boring I am afraid). Completely replaced the wiper motor and park switch in summer. Recently the wipers have taken to having a life of their own that is touchingly inconsistent! On intermittent instead of one wipe every 20 seconds or so, I get that sometimes but often one stroke, pause, three strokes, pause, one stroke etc. Also when I move from either intermittent or normal use to off it tends to carry on for between two and six extra wipes. Most disconcerting. I know fear that at some point I will switch them on needing the screen wiped and nothing will happen! I am guessing the park switch but cannot for the life of me work out what the fault could be. Surely you would expect a park switch to last more than four or five months??? Or is it something else going on? Any suggestions as to what is happening and how to sort would really be appreciated. Thanks Malcy Quote Link to comment Share on other sites More sharing options...
Big.Mike Posted November 25, 2013 Share Posted November 25, 2013 Try replacing the relay, fortunately I've not had this on my Defender. I have similar on other cars. I've found that if you replace something in a "system" like this then the next weakest component fails... Cheers, Mike Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 25, 2013 Share Posted November 25, 2013 I'm with Mike on the wiper relay. Mo Quote Link to comment Share on other sites More sharing options...
western Posted November 25, 2013 Share Posted November 25, 2013 IIRC my wipers [with intermittent relay] did a similar we'll do what we want, a new relay soon put a stop to the wipers unruly antics. Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted November 25, 2013 Author Share Posted November 25, 2013 Brilliant. ThanksWill look up which relay and then get one. Glad I asked since clearly changing the park switch (again) would have been futile!!! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 25, 2013 Share Posted November 25, 2013 Malcy, Now is a good time to upgrade to a variable intermittent wiper relay Mo Quote Link to comment Share on other sites More sharing options...
Litch Posted November 25, 2013 Share Posted November 25, 2013 I had similar issues and it was the delay relay not sitting in the connector correctly. Turned out one of the female spades wasn't latched properly and was being pushed out of the block when the relay was plugged in. Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted November 26, 2013 Author Share Posted November 26, 2013 Malcy, Now is a good time to upgrade to a variable intermittent wiper relay Mo Bit too close to Christmas I fear - broke!!! Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted November 28, 2013 Author Share Posted November 28, 2013 Replacement relay worked a treat. Thanks for the help Malcy Quote Link to comment Share on other sites More sharing options...
Big.Mike Posted November 28, 2013 Share Posted November 28, 2013 Cracking! That's great news. Quote Link to comment Share on other sites More sharing options...
Dumbsey Posted November 28, 2013 Share Posted November 28, 2013 Just a quick question, can you get an intermittent wiper relay for a 1985 90? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 28, 2013 Share Posted November 28, 2013 No Dumbsey, unfortunately not, you need to have intermittent wipers fitted. You can convert with an additional harness kit and the appropriate switch (you used to be able to buy a genuine harness but no longer, try autosparks perhaps) or google intermittent wiper kits for older cars. HTH Mo Quote Link to comment Share on other sites More sharing options...
western Posted November 28, 2013 Share Posted November 28, 2013 Just a quick question, can you get an intermittent wiper relay for a 1985 90? LR don't supply the wiring section anymore but either make your own up or Autosparks do a subsitute loom http://www.autosparks.co.uk/product_info.php?products_id=5128 in our tech archive is my short write up of how I fitted this system to my '89 110, http://forums.lr4x4.com/index.php?showtopic=927 plus other ways here http://forums.lr4x4.com/index.php?showtopic=20391&page=2 Quote Link to comment Share on other sites More sharing options...
Litch Posted November 29, 2013 Share Posted November 29, 2013 LR don't supply the wiring section anymore but either make your own up or Autosparks do a subsitute loom http://www.autosparks.co.uk/product_info.php?products_id=5128 in our tech archive is my short write up of how I fitted this system to my '89 110, http://forums.lr4x4.com/index.php?showtopic=927 plus other ways here http://forums.lr4x4.com/index.php?showtopic=20391&page=2 As above. Buy the Autosparks harness (was LR480 when I bought mine), delay relay (AMR2341) and wiper switch and away you go. All plug & play with no messing about necessary. Fitted this set-up to my 1986 90 a couple of years ago and it works a treat. Quote Link to comment Share on other sites More sharing options...
Dumbsey Posted November 29, 2013 Share Posted November 29, 2013 Ah right, thats good to know. Have to see if the portly jolly red man brings me some cash then! Thanks guys, helpful as always! Rhys Quote Link to comment Share on other sites More sharing options...
