muss12 Posted December 27, 2013 Share Posted December 27, 2013 Can anyone help please as the parts diagram shows this little gasket part number ERR2344 but doesn't show where it goes on the back of the casing, Is this importent to fit this gasket? Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted December 27, 2013 Share Posted December 27, 2013 Once you remove your casing you will see where it goes. I was advised to replace it when I was doing the water pump gasket as this is a common place for leakage, and to be honest you may as well do it while you are in there. Quote Link to comment Share on other sites More sharing options...
muss12 Posted December 27, 2013 Author Share Posted December 27, 2013 Thanks for the quick reply I've took the old casing off and can't see the old one, I'll have a good look tomorrow, by the parts diagram looks like it goes up near the camshaft Quote Link to comment Share on other sites More sharing options...
western Posted December 27, 2013 Share Posted December 27, 2013 IIRC it sits over a single bolt hole in centre area of the timing case, to prevent oil getting onto the timing belt. Quote Link to comment Share on other sites More sharing options...
muss12 Posted December 27, 2013 Author Share Posted December 27, 2013 Thanks Ralph Quote Link to comment Share on other sites More sharing options...
western Posted December 27, 2013 Share Posted December 27, 2013 your welcome, parts diagram isn't very accurate Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 27, 2013 Share Posted December 27, 2013 On the 200Tdi I think it goes between timing chest and block where the timing belt tensioner bolt goes through into the front of the block. There are two holes on the block, to account for the differing positions between Disco and Defender timing setups. Quote Link to comment Share on other sites More sharing options...
