Probably a question for the Guru which is Fridgefreezer
I have just purchased a universal 4 wire Lambda (oxygen) sensor off the bay of E.
It has 4 wires, 2 white, 1 black, 1 grey. But came with no wiring instruction, a quick hunt around the web (here) seems to suggest that the universal wiring for the sensors is black signal, grey earth, white heater.
So are white wires 2 x live? or 1 x live and 1 x earth in any combo?
As follows:
White - 12v switched }
White - ground } Heater
Black - Signal
Grey - Signal ground
[edit] quick websearch turns up - (here)
What they said - the two white 'uns will be heater, they don't matter which way round they're connected. Generally I connect them as above, if you don't get between 0 and 1v out of it (or you get -1v) then you have the black & grey reversed. Stick spade connectors on and it's an easy switch and you won't damage anything by having those wrong.
Jules - a nice idea but Rog is going MS, none of this open-loop Lucas nonsense :ph34r:
