o_teunico Posted February 5, 2014 Share Posted February 5, 2014 Hi all, Does anyone know if the factory steel wheels used on Series have the same offset as those fitted to Defenders? Quote Link to comment Share on other sites More sharing options...
tuko Posted February 5, 2014 Share Posted February 5, 2014 When the 110 and 90 were first introduced, they actually used leftover series 3 riveted steel rims. So my guess is yes the offsets are the same. I have a set in the garage that I can measure if need be. Todd. Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted February 5, 2014 Share Posted February 5, 2014 Early 110's and Defenders had reversed rims compared to Series wheels but the 110's outward offset was only about 4-6mm greater. Quote Link to comment Share on other sites More sharing options...
Daan Posted February 5, 2014 Share Posted February 5, 2014 a 5.5" wide series wheel should be the same offset as a defender as far as I can see, being +33mm. Only the forward control 6.5" wheels were +20 mm from memory. the TD5 wheels are welded rather than riveted, and the TDCI wheels are tubeless as well. They all fit the series. Daan Quote Link to comment Share on other sites More sharing options...
o_teunico Posted February 5, 2014 Author Share Posted February 5, 2014 +20 was the data I had for "Wolf" 6.5 rims. Thanks for the info! Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted February 5, 2014 Share Posted February 5, 2014 the forward control 6.5" wheels were +20 mm from memory. Daan 2b FC rims are 1mm out offset, 1 ton are 20.3mm inwards(like the other landy rims) Quote Link to comment Share on other sites More sharing options...
western Posted February 5, 2014 Share Posted February 5, 2014 XD/Wolf steels are 20.3mm too Quote Link to comment Share on other sites More sharing options...
