sammyb Posted February 22, 2014 Share Posted February 22, 2014 Right I've come to fitting my td5 dash and after putting the wiring on after having a bit of a look I'm after the bulbs an holders that fit into the gauges as my loom doesn't have them on where would I get them from?? Sam Quote Link to comment Share on other sites More sharing options...
Ibex94 Posted February 22, 2014 Share Posted February 22, 2014 I think you should find the gauges and warning lights are all LED's on the TD5 dash and that there are no lamps or holders. Rob Quote Link to comment Share on other sites More sharing options...
western Posted February 22, 2014 Share Posted February 22, 2014 normal type lights in the gauges, the bulb holder are part of the instrument pack loom & the all warning lights are a led circuit board. if no bulb holders have a look for them on VWP or polevolt websites. gauge lights are these http://www.retroanaconda.com/landrover/2009/10/td5-gauges-bulb-information/ Quote Link to comment Share on other sites More sharing options...
sammyb Posted February 22, 2014 Author Share Posted February 22, 2014 Hi bud, I've had a look on a td5 def in a friends workshop an his has plugs that go into the gauge, I only have the two small bulbs for the vents Quote Link to comment Share on other sites More sharing options...
western Posted February 22, 2014 Share Posted February 22, 2014 someone has removed the gauge bulb holders from the loom then, they look like this plugs on the red & black wires & a bulb holder with 2 male spade terminals, you can see the 3 on this photo. from http://www.retroanaconda.com/landrover/2009/10/installing-defender-td5-gauges-into-a-200tdi300tdi/ Quote Link to comment Share on other sites More sharing options...
PaulMc Posted February 23, 2014 Share Posted February 23, 2014 The TD5 gauge bulb holders are part number - YAJ100390 http://www.rimmerbros.co.uk/Item--i-YAJ100390 . Quote Link to comment Share on other sites More sharing options...
sammyb Posted February 23, 2014 Author Share Posted February 23, 2014 That's them, thank you!! Could not find them on eBay!! Quote Link to comment Share on other sites More sharing options...
