muddy4x4xfar Posted February 27, 2014 Share Posted February 27, 2014 hi all maybe a silly question but just want to check. will defender 300tdi front vented calipers fit my 200tdi defender? i only ask as i want vented front brakes and cant seem to find any for a 200 tdi so im assuming they didnt have them . cheers all Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted February 27, 2014 Share Posted February 27, 2014 depends on the year of your 90 i presume, Do you know if your 90 has 10 or 24 spline axles? Some of the last 200tdi 90's (and discoverys) got sent out the factory with the later, 300tdi spec, 24 spline axles. You could, if you find your on 10spline, swap the front axle for a 24 spline unit. Quote Link to comment Share on other sites More sharing options...
muddy4x4xfar Posted February 27, 2014 Author Share Posted February 27, 2014 its a 110 high capacity pick up. with 24 spline half shafts Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted February 27, 2014 Share Posted February 27, 2014 If your car is post-1991 then the vented calipers should fit fine. You'll obviously need a set of vented discs too. Pre-1991 it might well fit, but I'm not 100% sure. Vented front became standard fit on long-wheelbase models from 300Tdi onwards. Was an option on short-wheelbase. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted February 27, 2014 Share Posted February 27, 2014 Don't forget you need 110 vented calipers as 90's had smaller calipers (the same size as discos iirc) though I think they changed later 90/110 to the same size but don't quote me on that. Mike Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted February 27, 2014 Share Posted February 27, 2014 Yes, 1991 was the change. So almost all 200Tdi vehicles will have rationalised front calipers. From that point on all 90/110 used the same four-pot calipers and the same diameter discs in one of two width variations (vented/standard). As long as you change the disc as well to match the caliper then they are interchangeable. The above is true for the front brakes, rears are another matter and differed with the wheelbases. Quote Link to comment Share on other sites More sharing options...
muddy4x4xfar Posted February 27, 2014 Author Share Posted February 27, 2014 thats brilliant guys thanks for all your help. Quote Link to comment Share on other sites More sharing options...
