zim Posted April 24, 2014 Share Posted April 24, 2014 Yes, i know they're available - but we knocked one up out of a a modified air ram we had. Machined a new piston for it, with a pin on the end. Made a boss for the ram to screw into and also be a guide for the piston pin. Drilled out and tapped the TDS housing to accept this boss. (Stainless) Piston in progress : Bad picture, but mounted in the boss in housing : G Quote Link to comment Share on other sites More sharing options...
mickeyw Posted April 24, 2014 Share Posted April 24, 2014 Looks good, but quite a lot bulkier than the Goodwinch version. I made my own air cylinder from Acetal rod, mainly because the position of my TDS winch in relation to the spot lights required something lower profile. Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted April 26, 2014 Share Posted April 26, 2014 Never really thought about how the free spool works on the tds until now but I am copying that idea Quote Link to comment Share on other sites More sharing options...
zim Posted April 26, 2014 Author Share Posted April 26, 2014 Our rear winch quick modification isn't as high tech, but just as effective G Quote Link to comment Share on other sites More sharing options...
simonr Posted April 27, 2014 Share Posted April 27, 2014 What grade of steel did you make the pin from? I made a solenoid operated version using EN8 - and after a few months, it sheared! Replacement was EN24 which survived. It's why the Goodwinch version re-uses the original pin. Si Quote Link to comment Share on other sites More sharing options...
