boyt Posted May 29, 2014 Share Posted May 29, 2014 Hello, I have change the clutch on my td5 2000 disco, I changed the flywheel, clutch, release bearing, fork plastic bush, pushrod, slave cylinder, I now have a clutch that slips on light acceleration and a high clutch pedal, What's your thoughts? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 29, 2014 Share Posted May 29, 2014 Have you adjusted the foot pedal base to 140mm from ffloor? Quote Link to comment Share on other sites More sharing options...
boyt Posted May 29, 2014 Author Share Posted May 29, 2014 Thanks for your reply, don't suppose you have a link to how to do it, Thanks in advance, ment to be going to seven sisters tomorrow Quote Link to comment Share on other sites More sharing options...
bear Posted May 29, 2014 Share Posted May 29, 2014 Hi boyt, Had a look in Haynes and Rave and can't see any mention of pedal height adjustment. Maybe the TD5 doesn't have any unlike the D1 (Unless I'm missing something of course ) Griff Quote Link to comment Share on other sites More sharing options...
sierrafery Posted May 29, 2014 Share Posted May 29, 2014 there's no such adjustment for D2, the only thing can think is bad clutch quality(unless it's Valeo) or the drive plate was fitted the other way round, are you certain that the flywhel side of it was took in account... happened to me(and others too) that some schmucks fitted it wrong... though then it's hard to put it in gear too Quote Link to comment Share on other sites More sharing options...
boyt Posted May 29, 2014 Author Share Posted May 29, 2014 I have put 2 sets of clutchs in both valeo, valeo dmf, clutch is 100% right way around, Quote Link to comment Share on other sites More sharing options...
