dave88sw Posted June 22, 2014 Share Posted June 22, 2014 Hi, Sorry for asking this here but it covers any Land Rover with a V8 so feel it would get a better response here than the discovery section. My 3.9 Discovery has a horrible rattle from the cats, seen it on loads of cars over the years and usually the best solution is a new cat. However, i've known lots of people cut open the cat, scoop out the middle (or just the loose bits) and then weld it back together. I'm all for this as i just haven't got the money for a new y piece with cats. My question is, how close to the limit do most V8's seem to be on the emmisions test, will i have trouble getting it through the test with a large portion of the cat missing? My other thought (probably a stupid one) is to get a non cat y piece (much cheaper) and a universal cat and just put the one cat on behind the y piece rather than one on each branch? But are cats special to each vehicle (i.e. are they an optimum size or surface area?) Any suggestions would be appreciated. Cheers Dave Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 23, 2014 Share Posted June 23, 2014 What year is the disco? You will need to keep the cats if after 92, unless getting on tested on lpg. Quote Link to comment Share on other sites More sharing options...
dave88sw Posted June 23, 2014 Author Share Posted June 23, 2014 It's a 97, i know the cats need to be present, i'm not usually one to try and skimp on bits but i really cant afford a new y piece. I suppose the only option is to try and remove the loose bits and then get an emmissions test done to see if it's made a big difference. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 23, 2014 Share Posted June 23, 2014 Careful, lots of carcinogens in them.... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 23, 2014 Share Posted June 23, 2014 I very much doubt you'll pass the emissions test for cats without them, when my Freelander's cat broke up internally it failed the MOT by miles on emissions, new cat & it went through perfect. The stuff inside may be nasty but it's high value as scrap, contains platinum and all sorts - for a while people were going round stealing them when scrap prices were proper high! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 23, 2014 Share Posted June 23, 2014 Indeed, the limits are totally different to a non-cat test. Quote Link to comment Share on other sites More sharing options...
dave88sw Posted June 23, 2014 Author Share Posted June 23, 2014 Thanks for the advice guys, pretty much what i expected to hear. The MOT isn't due until april so i have a while to ponder over what to do. I had intended to LPG it so maybe i'll bring that forward, then i can quite happily remove the cats. Quote Link to comment Share on other sites More sharing options...
