xychix Posted August 10, 2014 Share Posted August 10, 2014 Is the square nut on top of the steering housing the one to use to adjust steerplay? I had to scrape a lot of grease off of the housing to discover nuts there. Quote Link to comment Share on other sites More sharing options...
tacr2man Posted August 10, 2014 Share Posted August 10, 2014 have alook here http://www.retroanaconda.com/landrover/manuals/series3wm/5_axles_steering_brakes.pdf Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 10, 2014 Share Posted August 10, 2014 It should be on the side - the one on top is to top up the box. Which you should do every service! Quote Link to comment Share on other sites More sharing options...
xychix Posted August 10, 2014 Author Share Posted August 10, 2014 It should be on the side - the one on top is to top up the box. Which you should do every service! uhm, now I understand the grease there... it seems all holes apart from the engine take 80W90.... same here? Quote Link to comment Share on other sites More sharing options...
