Johannadine Posted August 12, 2014 Share Posted August 12, 2014 Hi Everyone, I need advice i have a land rover 3.9 v8 when i start it. it takes about 10 seconds before it goes off i then also have noisy tappets which comes and goes. Does anyone have advice for me. Thanks Quote Link to comment Share on other sites More sharing options...
Tanuki Posted August 12, 2014 Share Posted August 12, 2014 Sounds like the oil-filter is draining itself when the engine's stopped. You are using a genuine oil-filter? There should be a valve inside the filter that stops this drain-down. A lot of the 'pattern' parts do not include this. Could also be a sticking pressure-relief valve in the oil pump. Finally, what oil are you using?? Rover V8s don't play nicely with modern runny-as-Australian-lager oils - a 15W50 is about as thin as I'd go [the original RV8 specified 20W50] Quote Link to comment Share on other sites More sharing options...
Johannadine Posted August 12, 2014 Author Share Posted August 12, 2014 Thanks. how can i take the relief valve out. and how many relief valves are there can a person service a oil pump Quote Link to comment Share on other sites More sharing options...
Johannadine Posted August 13, 2014 Author Share Posted August 13, 2014 Hi Everyone, I need advice i have a land rover 3.9 v8 when i start it. it takes about 10 seconds before the oil light goes off i then also have noisy tappets which comes and goes. Does anyone have advice for me. Thanks Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 13, 2014 Share Posted August 13, 2014 1st thing: Are you using thick enough oil? You want 20W50, 15W40, or 10W40. 2nd: Is the oil filter genuine parts or something else? Best not to start dismantling the oil pump until you've checked the basics. Quote Link to comment Share on other sites More sharing options...
Johannadine Posted August 13, 2014 Author Share Posted August 13, 2014 Hi Fridge Freezer, I am using Castrol 20W50 and yes it is the Genuine filter. The tappet noise is only on the right side. Quote Link to comment Share on other sites More sharing options...
Team Idris Posted August 14, 2014 Share Posted August 14, 2014 It could be the relief valve stuck open? Mine did this on the 3.5 RV8. The bad news is that it did this because it was jammed with bits of cam shaft. But they do jam open without needing an engine re-build. Pop the lid off and have a look at the valve and the gears Quote Link to comment Share on other sites More sharing options...
Johannadine Posted August 14, 2014 Author Share Posted August 14, 2014 What would happen if i put a thicker spring in so it does not open so quickly. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted August 14, 2014 Share Posted August 14, 2014 What would happen if i put a thicker spring in so it does not open so quickly. If the relief-valve-s plunger is jamming partially-open, a thicker spring won't help [unless it's massively-powerful, in which case you might as well not have a relief-valve and then you'll go on to blowing seals and bursting oil-filter canisters when you do a cold-start in winter]. Fix the underlying problem, rather than trying to fudge-and-kludge it. Quote Link to comment Share on other sites More sharing options...
Johannadine Posted August 14, 2014 Author Share Posted August 14, 2014 ok thank you very much Quote Link to comment Share on other sites More sharing options...
Johannadine Posted August 14, 2014 Author Share Posted August 14, 2014 only the one side number 1 piston tappet is making a noise (clicking noise) could that be due to the oil pressure. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted August 14, 2014 Share Posted August 14, 2014 Fix the oil-pressure issues. Run it with fresh oil - then after 500 miles add a pint of ATF to the oil. ATF is well-stuffed with detergents and will remove time-accumulated varnish and grot from the lifters. Run it with ATF-in-the-oil for 500 miles. Drive-it-like-you-stole-it; lots of full-throttle-and-don't-shift-until-you-run-out-of-revs. Then do an oil-change - which will bring out all the accumulated lacquer-varnish-and-sludge. If you're inclined - also drop the sump and clean the mesh-filter on the oil pickup-pipe. Quote Link to comment Share on other sites More sharing options...
Johannadine Posted August 15, 2014 Author Share Posted August 15, 2014 Ok Thank you very much. I will try it. Quote Link to comment Share on other sites More sharing options...
