DefcoL Posted October 26, 2006 Share Posted October 26, 2006 Please help . Driving along with no probs on steering, stopped outside shop and kept enging running , went to pull away and f88k me the steering needed popeye to turn the wheel.......... chkd oil res and all ok belt seem ok... this realy was a pull up ok and pull away with what seem like no power steering Any one got the ans as to what it could be??? TIA Lawrence Quote Link to comment Share on other sites More sharing options...
LR90 Posted October 26, 2006 Share Posted October 26, 2006 PAS Pump? Is there any sign that fluid is being circulated and returned to the reservoir? Quote Link to comment Share on other sites More sharing options...
Andy Posted October 26, 2006 Share Posted October 26, 2006 yep sounds like pump to me as well. a mates defender once lost power steering because the magnet in the pump to collect swarf moved & blocked the intake. Quote Link to comment Share on other sites More sharing options...
DefcoL Posted October 26, 2006 Author Share Posted October 26, 2006 yep sounds like pump to me as well. a mates defender once lost power steering because the magnet in the pump to collect swarf moved & blocked the intake. OH...! Quote Link to comment Share on other sites More sharing options...
DefcoL Posted October 26, 2006 Author Share Posted October 26, 2006 PAS Pump?Is there any sign that fluid is being circulated and returned to the reservoir? the res is full ........ Quote Link to comment Share on other sites More sharing options...
freeagent Posted October 26, 2006 Share Posted October 26, 2006 pump. my defender went a bit like that, the pump isn't servicable, so its around £100 for a new one from one of the 'addocks. m@tt Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted October 26, 2006 Share Posted October 26, 2006 I think Andy managed to "service" his. He has photos if I remember. Wake up Andy. Quote Link to comment Share on other sites More sharing options...
Andy Posted October 26, 2006 Share Posted October 26, 2006 me wake up? that'd be a first. you can get a 200tdi pump apart if your careful. its easy enough to work out as you go along, the basic order of things (its been a few years since i did it) is remove the pump - obvious eh? remove the pressure relief valve the body of the pump looks like a can, it will press off backwards with a screwdriver worked around the top then there is 4 bolts holding the back on the pump itself. then the rotor & vanes lift/fall out, there is a key holding the rotor to the shaft (if the bearing retaining clip in the front of the pump goes it will eat this key killing the pump) then the plate the pulley bolts to will slide/drift (needs pressure/gentle hammer) off the shaft followed by the plastic dust cover then you see the spring clip retaining the bearing, remove that & the shaft slides out forward. i replaced the bearing in mine when it died for about £6 from BTR bearings. any bearing specialist should manage to match it i believe. there is also an oil seal on the shaft behind the rotor. heres a few pics i took as went along inside the 'can' you can see where the magnet goes bottom left of the body in that slot the rotor & vanes all the bits that acceptable mark? Quote Link to comment Share on other sites More sharing options...
DefcoL Posted October 27, 2006 Author Share Posted October 27, 2006 me wake up? that'd be a first. you can get a 200tdi pump apart if your careful. its easy enough to work out as you go along, the basic order of things (its been a few years since i did it) is.................. thanks for help... have just phoned local store who will supply pump for 76+v sounds reasonable to me as will be returnable in first yr if it doesnt hold up..... but would realy like to establish if it realy is the pump.... Are there any set tests I can do to eliminate al else..? Tia Lawrence Quote Link to comment Share on other sites More sharing options...
white90 Posted October 27, 2006 Share Posted October 27, 2006 open bleed nipple on power steering box start engine the turn the steering wheel the more you turn it the higher the fountain of ATF will be till it hits the bonnet(best done at a petrol station in front of thier pressure washer) that way you can clean the car and pop into the garage for some more ATF if there is no fountain the pump is Dead. ps don't stand near the fountain as hell does it go everywhere.(experience talking) Quote Link to comment Share on other sites More sharing options...
DefcoL Posted October 27, 2006 Author Share Posted October 27, 2006 open bleed nipple on power steering boxstart engine the turn the steering wheel the more you turn it the higher the fountain of ATF will be till it hits the bonnet(best done at a petrol station in front of thier pressure washer) that way you can clean the car and pop into the garage for some more ATF if there is no fountain the pump is Dead. ps don't stand near the fountain as hell does it go everywhere.(experience talking) Thanks Tony Will get to it at daybreak hoping it is that so at least I know what to change Quote Link to comment Share on other sites More sharing options...
DefcoL Posted October 28, 2006 Author Share Posted October 28, 2006 open bleed nipple on power steering boxstart engine the turn the steering wheel the more you turn it the higher the fountain of ATF will be till it hits the bonnet(best done at a petrol station in front of thier pressure washer) that way you can clean the car and pop into the garage for some more ATF if there is no fountain the pump is Dead. ps don't stand near the fountain as hell does it go everywhere.(experience talking) well...... opened nipple, started engine, not even a dribble So off to dingocroft to get pump £75+v pluss 2 lts oil wonder what will go next..........??? best go and earn some more money Quote Link to comment Share on other sites More sharing options...
