davidharvey Posted August 28, 2014 Share Posted August 28, 2014 Bit of a daft sounding question, but is it ok to support a defender on axle stands below the axle? I know the clue is in the name, but on some vehicles it is not recommended as it can bend the axle tube. Quote Link to comment Share on other sites More sharing options...
SPendrey Posted August 28, 2014 Share Posted August 28, 2014 You should be fine anywhere along the axle tube, but it is not recommended on the trailing arm bolt/links or radius arm joints at the front. I'd also suggest as far outwards as possible to increase stability. I tend to jack up at the diff, and place stands as far along the axle as possible. Quote Link to comment Share on other sites More sharing options...
davidharvey Posted August 28, 2014 Author Share Posted August 28, 2014 You should be fine anywhere along the axle tube, but it is not recommended on the trailing arm bolt/links or radius arm joints at the front. I'd also suggest as far outwards as possible to increase stability. I tend to jack up at the diff, and place stands as far along the axle as possible. Thank you. And so the work can begin Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted August 28, 2014 Share Posted August 28, 2014 I tend to stick them directly under the spring seats, but anywhere along the axle tube itself is load bearing providing the stand is located properly. I've heard people say not to jack off the bottom of the trailing arms or radius arms, as the weight is then taken by the bushes and apparently it can damage them. I'm not sure how true this is. Quote Link to comment Share on other sites More sharing options...
