muddy Posted September 14, 2014 Share Posted September 14, 2014 What does this little beauty do best? I'm guessing mates something to an lt230 bit just what? Your thoughts please....... Will. Quote Link to comment Share on other sites More sharing options...
Diff Posted September 14, 2014 Share Posted September 14, 2014 Is it a remote LT230 transferbox conversion plate? Propshaft/input flange slides over the short shaft and is secured by centre nut. The other goes into the transferbox and engages with the input drive gear? Regards, Diff. Quote Link to comment Share on other sites More sharing options...
sean f Posted September 14, 2014 Share Posted September 14, 2014 Is it a remote LT230 transferbox conversion plate? Propshaft/input flange slides over the short shaft and is secured by centre nut. The other goes into the transferbox and engages with the input drive gear? Regards, Diff. Thats my guess as well, splines look about right to take drive flange from a diff or lt230. Quote Link to comment Share on other sites More sharing options...
muddy Posted September 14, 2014 Author Share Posted September 14, 2014 Diff flanges are fine aren't they? But good call on the t box flanges I must investimergate further...... Quote Link to comment Share on other sites More sharing options...
elbekko Posted September 15, 2014 Share Posted September 15, 2014 The long side does look like it'd go into an LT230. The short side has strange splines though, so probably fairly useless unless you also have the flange that goes on there. Quote Link to comment Share on other sites More sharing options...
dave88sw Posted September 15, 2014 Share Posted September 15, 2014 All the early 10 spline diff flanges i've taken off have had those 4 big splines, later 24 spline ones have fine splines. Quote Link to comment Share on other sites More sharing options...
elbekko Posted September 15, 2014 Share Posted September 15, 2014 Oh, that explains then. Never seen those before. Quote Link to comment Share on other sites More sharing options...
