michael calvert Posted October 30, 2006 Share Posted October 30, 2006 where the hell do you top up the ATF level in these things, can find a dipstick (other than what feels like me at the mo) or any bungs that appear high enough up i know they need filling up when running and are in drive but still can find where to put the fluid in, please help ps its a 51 plate bmw Tdi effort Quote Link to comment Share on other sites More sharing options...
SteveG Posted October 30, 2006 Share Posted October 30, 2006 visit www.rangerovers.net you'll find instructions there and lots of help for the P38a Steve Quote Link to comment Share on other sites More sharing options...
nas90 Posted October 30, 2006 Share Posted October 30, 2006 The auto on the NAS is a ZF 4 speed pinched from a RR Classic. The fill hole is the dipstick hole so you need a 1 litre plastic bottle of ATF with the long thin spout that fits the tube holding the dipstick. To check the fluid level from cold, start the engine and with your foot on the footbrake go down from park to first and back again a few times, holding in each position, which ensures that the ATF has circulated all the valves. Select neutral with handbrake on and with engine still running check the fluid level. If ATF needed cut engine, top-up, check from above sequence. If you do not have ZF then this might be wrong info! Quote Link to comment Share on other sites More sharing options...
michael calvert Posted October 30, 2006 Author Share Posted October 30, 2006 The auto on the NAS is a ZF 4 speed pinched from a RR Classic.The fill hole is the dipstick hole so you need a 1 litre plastic bottle of ATF with the long thin spout that fits the tube holding the dipstick. To check the fluid level from cold, start the engine and with your foot on the footbrake go down from park to first and back again a few times, holding in each position, which ensures that the ATF has circulated all the valves. Select neutral with handbrake on and with engine still running check the fluid level. If ATF needed cut engine, top-up, check from above sequence. If you do not have ZF then this might be wrong info! no it is a ZF but there only appears to be a couple of inlets/outletys to the damn thing and these are taken up by pipes running to the cooler just going to check the link now. cheers Quote Link to comment Share on other sites More sharing options...
michael calvert Posted October 30, 2006 Author Share Posted October 30, 2006 no it is a ZF but there only appears to be a couple of inlets/outletys to the damn thing and these are taken up by pipes running to the coolerjust going to check the link now. cheers couldnt seem to find anything on the www.rangerovers.net site, anyone else able to help ........... please (will also post this in vehicles forum Quote Link to comment Share on other sites More sharing options...
ashtrans Posted October 30, 2006 Share Posted October 30, 2006 couldnt seem to find anything on the www.rangerovers.net site, anyone else able to help........... please (will also post this in vehicles forum if you have a close look at the sump on the autobox you will find a hole at the bottom which is the drain and one on the front face which is the filler / level plug, fill until it overflows, start the engine, it will suck up the oil straight away so you need to then pump like crazy to replenish it, once it starts to stabilise, go up and down the gears, a few seconds in each position, check again, put plug in. test drive and recheck. Quote Link to comment Share on other sites More sharing options...
