Andrew Cleland Posted December 12, 2014 Share Posted December 12, 2014 I'm noticing a bit of knocking coming from the back-end of the 110 going over speedbumps and the like. Exhaust seems solid so started looking at the suspension. I spotted a bit of a gap between the steel plate and the rubber on the rear lower arm bushes, so I removed the nuts, copperslipped the threads and fitted new Nyloks torqued to the Mr Haynes specified 131ft.lbs but the gap is still there. Is this normal, are these standard bushes - I didn't think Land Rover bushes had the big washers at each end, but it's an ex-police 110 and they assured me they only used Genuine Parts for servicing... Quote Link to comment Share on other sites More sharing options...
reb78 Posted December 12, 2014 Share Posted December 12, 2014 Thats what mine looks like Andrew. A frame ball joint perhaps? What are the bushes at the other end of the trailing arms like? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 12, 2014 Share Posted December 12, 2014 It is normal to have a small gap, but it could be that your gap is too big. Get a breaker bar or the like in there and see if you can force the washer/arm/axle back and forth. You can also check them by having someone push the vehicle back/forth against the handbrake and seeing if there is movement underneath. A-frame is also a good shout, as are shock bushes. Quote Link to comment Share on other sites More sharing options...
Andrew Cleland Posted December 12, 2014 Author Share Posted December 12, 2014 Thanks both, I'll take them as OK then. A-frame joint is a possibility, but from memory of the last one I did, can be a right sod to get at/out. I'll have a play with the jemmy and see what I can find! A. Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted December 12, 2014 Share Posted December 12, 2014 Id bet on shock bushes Quote Link to comment Share on other sites More sharing options...
