Simon_CSK Posted December 23, 2014 Share Posted December 23, 2014 I posted previously about my remote not unlocking the car. Having not used the car for a while I went out to charge the battery and could not disable the alarm. Now I cannot start the car or move it with the remote or with the key. Any ideas? Quote Link to comment Share on other sites More sharing options...
sierrafery Posted December 24, 2014 Share Posted December 24, 2014 if the battery went flat with locked car now it's immobilised, you need the EKA code to remobilise it as long as the fob doesnt work, you can try your luck and replace the roof receiver maybe that was your initial problem then the fob will work and you cab disarm the immobiliser Quote Link to comment Share on other sites More sharing options...
dave88sw Posted December 24, 2014 Share Posted December 24, 2014 The EKA code should get it running but your fob will still not work, the simplest answer is to buy a new remote receiver and fit it, all functions will then be restored. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted December 24, 2014 Share Posted December 24, 2014 Before buying a new rf receiver take a look at the large grey multiplug behind the trim at the bottom of the LH A pillar.These are prone to water ingress from sunroof and windscreen leaks. Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted December 24, 2014 Author Share Posted December 24, 2014 Before buying a new rf receiver take a look at the large grey multiplug behind the trim at the bottom of the LH A pillar.These are prone to water ingress from sunroof and windscreen leaks. Ally Tell me more please. I think water ingress is my problem despite refitting the sunroof over the summer. The last 24 hours I have had a fan heater in my car and it has sorted some problems. The car now starts and runs but the key fob is strange as it only locks the car when it is in the lock and will not unlock it under any circumstances. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted December 25, 2014 Share Posted December 25, 2014 Just pull the multiplug apart and look for green gunge in the connections. On some I have had to cut wires away from the plug and remake the joint away from the multiplug.More common on cars with leaky sunroofs... Quote Link to comment Share on other sites More sharing options...
sierrafery Posted December 26, 2014 Share Posted December 26, 2014 Ally Tell me more please. I think water ingress is my problem despite refitting the sunroof over the summer. The last 24 hours I have had a fan heater in my car and it has sorted some problems. The car now starts and runs but the key fob is strange as it only locks the car when it is in the lock and will not unlock it under any circumstances. Water ingress can affect directly the BCU or the interior fusebox too and that can cause such kind of trouble... though the tip with that grey connector at the A-post is spot on... you say the key locks but doesnt unlock but can you unlock with the dash switch?(this would rule out the central locking only cos it doesnt work with the alarm), as long as you can start the car after you unlocked with the key even if the central locking doesnt work it means that the driver's door switch works cos it disables the immobiliser(which means it's set for that).... i must insist that as long as the fob doesnt work at all and you dont find corrosion in that plugat also as there was some sunroof leak you should replace the roof receiver to rule it out Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted December 30, 2014 Author Share Posted December 30, 2014 Ok now acquired a new receiver can someone tell me where to put it..........No smutty answers please! Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted December 30, 2014 Share Posted December 30, 2014 OK, its above the head lining,remove the trim around the rear sunroof and gently pull the lining down a couple of inches.Looking towards the front of the car you will see it bolted to the roof just left of centre.Good luck. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted December 30, 2014 Share Posted December 30, 2014 Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted December 30, 2014 Author Share Posted December 30, 2014 Thanks guys for all your help remote now fully functioning I knew as soon as I got it off the receiver was the problem there was a little copper corrosion showing on the plastic of the box. Switched it over and everything works as it should. Quote Link to comment Share on other sites More sharing options...
