sgnas Posted January 25, 2015 Share Posted January 25, 2015 I need to rebuild a front stub axle on a 1998 110 (although the parts will be the same on most similar aged axles) Apart from wheel bearings, locknuts washers etc. which I carry spares of already, what do I need. List so far. Stub axle ftc3154 Seal ftc5268 Thrust bearing ftc56 Needle bearing ftc861 Gasket ftc3648 Quote Link to comment Share on other sites More sharing options...
western Posted January 25, 2015 Share Posted January 25, 2015 all the new bits are listed in http://lrcat.com/#31/4/52605 what's wrong with the existing stub axle, if lightly scored, just polish out the scores with emary paper of varying grades. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 25, 2015 Share Posted January 25, 2015 Before buying the thrust bearing and the seal, check with your chosen supplier... my genuine front stub axles I bought off Nigel a few years ago had them already installed. Quote Link to comment Share on other sites More sharing options...
sgnas Posted January 25, 2015 Author Share Posted January 25, 2015 all the new bits are listed in http://lrcat.com/#31/4/52605 what's wrong with the existing stub axle, if lightly scored, just polish out the scores with emary paper of varying grades. The inside inner race is stuck tight. Slit it in 3 places with a dremel, still stuck. Run a weld bead around it to heat it, still stuck. Left it in the freezer overnight, still stuck. For the sake of £50 of parts I'd prefer it mobile while I faff around at my leisure to get the race off. Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted January 26, 2015 Share Posted January 26, 2015 I've just stripped my rrc axles if you want any parts. Quote Link to comment Share on other sites More sharing options...
