Texpis Posted March 2, 2015 Share Posted March 2, 2015 Hi all a bit of advice please. I have bought a series 3 with a known gearbox problem. The gearbox was replaced with an recon unit after 6 months it started to stick in gear you literally can't get it out of gear until you Rev the engine a bit. He was going to send the gearbox back but with family problems it got dumped in his garden for about 5 years. I have just repaired the footwells and serviced the engine and done loads of other jobs thinking I can get away with the gearbox problem, it when for a drive today and it's imposible to drive I believe it's mainly third and it happens after acceleration and deceleration. I know it's a gear box out but is it an easy repair? Bearing etc should be okay what do you think. Oh and it's a 1982 so I believe that is the later type box. Mick Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 2, 2015 Share Posted March 2, 2015 Sound more like a clutch problem to me. It might need new clutch plates, a clean up of the flywheel and a new spiggot bush to stop the clutch from sticking. Quote Link to comment Share on other sites More sharing options...
HoggyN Posted March 2, 2015 Share Posted March 2, 2015 As above. I had the same problem once. The clutch wasn't disengaging fully. A few turns of the linkage adjusting nuts sorted it. Not sure what you would do on a S3 though. Leaky master/slave cylinder? Quote Link to comment Share on other sites More sharing options...
Texpis Posted March 2, 2015 Author Share Posted March 2, 2015 Hmm thanks for that will look into it Mick Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 2, 2015 Share Posted March 2, 2015 Poor bleeding would also do it - I find I need to elevate the front to bleed properly (parking up hill is enough). A failing flexi-hose could also do it. Quote Link to comment Share on other sites More sharing options...
xychix Posted March 2, 2015 Share Posted March 2, 2015 for my sIII the flexhose was broken. a bugger to reach but not that expensive to replace. Quote Link to comment Share on other sites More sharing options...
Texpis Posted March 5, 2015 Author Share Posted March 5, 2015 Okay guys clutch well and truly bled I conviced there is no air in the system. Bit more info on the problem, in third gear it seems like it pops out of gear but it doesn't if you see what I mean. If you try and change gear then it won't come out, if you push it back into gear then it will change. Second gear is ver Granchy (is there such a word) and jumps out of gear. Mick Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 5, 2015 Share Posted March 5, 2015 It could be a loose main shaft nut inside the transfer box making the second gear noise and allowing the shaft to move longitudinally, giving the impression of third moving. I doubt it's related to the sticking in gear, unless the bearings are so worn that the shafts are skewing. Quote Link to comment Share on other sites More sharing options...
Serious Series Posted March 5, 2015 Share Posted March 5, 2015 Is the ball on the selector end of the gearstick located correctly or maybe badly worn or the locating screw worn in the alloy housing Quote Link to comment Share on other sites More sharing options...
