defender dinky Posted May 15, 2015 Share Posted May 15, 2015 hi, I need part number for defender 110 td ex mod some say range rover classic will fit is this so, dd Quote Link to comment Share on other sites More sharing options...
pete3000 Posted May 15, 2015 Share Posted May 15, 2015 ntc2017? guard esr 2204 Quote Link to comment Share on other sites More sharing options...
defender dinky Posted May 15, 2015 Author Share Posted May 15, 2015 thks pete3000 Quote Link to comment Share on other sites More sharing options...
defender dinky Posted June 17, 2015 Author Share Posted June 17, 2015 hi, can anyone tell me part number for fuel sender to fit the ntc2017/wfeooo190 and do I need any gaskets to fit the sender, dd Quote Link to comment Share on other sites More sharing options...
western Posted June 17, 2015 Share Posted June 17, 2015 Gasket & locking ring usually come with the new sender Quote Link to comment Share on other sites More sharing options...
pete3000 Posted June 19, 2015 Share Posted June 19, 2015 the sender is PRC8463 early type? or AMR1495 gasket and union kit here, has all the bits you need, not convinced of the green composite washer though. http://www.island-4x4.co.uk/fuel-tank-fitting-genuine-wfe000190kit-esr2000kit-nrc7570kit-p-6638.html however also get a esr3278 and use some sealant or fibre washers on your pickup tube screws as the bearmach tanks don't use blind holes allowing the diesel to leak past the pickup tube Quote Link to comment Share on other sites More sharing options...
defender dinky Posted July 2, 2015 Author Share Posted July 2, 2015 got fitting kit, now after fuel pipes complete from tank to sediment to engine bay for 110 fuel tank ntc2017 any part numbers anyone dd Quote Link to comment Share on other sites More sharing options...
western Posted July 2, 2015 Share Posted July 2, 2015 fuel pipes in pages 536 to 539 http://www.retroanaconda.com/landrover/parts_books/110/6_vehicle_controls_brakes_fuel_air_p472-579.pdf Quote Link to comment Share on other sites More sharing options...
defender dinky Posted July 2, 2015 Author Share Posted July 2, 2015 good info sorted now thks Quote Link to comment Share on other sites More sharing options...
