need4speed Posted June 17, 2015 Author Share Posted June 17, 2015 MTC3499 has been superseded though. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 17, 2015 Share Posted June 17, 2015 Looking at your pics, the holes in the new one are just too small to put the brass inserts in, right? I think they are like that as part of a redesign.... that uses self tappers. You can see the walls of the tubes are fatter, so I would think with the right size screw in it it wouldn't split. That said you would expect them to send them out with the new cowling, but hey, you can't get everything right Brass is expensive, and in this instance actually not bringing anything to the party. I can't believe I just sort-of defended Britpart, hey once in 10 years is OK I suppose. Quote Link to comment Share on other sites More sharing options...
western Posted June 17, 2015 Share Posted June 17, 2015 the cover in http://lrcat.com/#30/4/45136 now uses self tapping screws item 3 in the parts link, which comes out as http://www.lrseries.com/shop/product/listing/17740/DA608084L-SCREW-SELF-TAP.html?search=DA608084L&page=1 screw self tapping M8 x 25mm Quote Link to comment Share on other sites More sharing options...
need4speed Posted June 17, 2015 Author Share Posted June 17, 2015 M8 x25mm wouldn't reach. The original M5 screws are 40mm long? Quote Link to comment Share on other sites More sharing options...
