Paul64 Posted November 14, 2006 Share Posted November 14, 2006 Hi, I wanted to clean the Engine Breather Filter, and then replace the gasket on my 200Tdi. I bought a gasket from Rimmer Bros, but it doesn't look like the gasket I need. Is there an onlime parts book, so you know you have the right number for the part you need? Does anyone know what the part number is for this gasket? In the Haynes manual it says two bolts retain the filter to the valve cover, but the gasket I received has 6 holes in it?? Cheers, Paul Quote Link to comment Share on other sites More sharing options...
western Posted November 14, 2006 Share Posted November 14, 2006 If it's the round black canister [cyclonic breather] bolted to the right of the cylinder head above the vacuum pump, you need 1 x 'O' ring seal part number LLO100000, the canister is held by 1 x 100mm hex head bolt & the 2 hoses by jubilee clips. if it's the engine block side cover next to the injection pump you need 1 x gasket ERR2026 [Not all 200Tdi have this breather cover fitted - it was deleted on later engines & the cyclonic breather above was used on it's own] Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 14, 2006 Author Share Posted November 14, 2006 If it's the round black canister [cyclonic breather] bolted to the right of the cylinder head above the vacuum pump, you need 1 x 'O' ring seal part number LLO100000, the canister is held by 1 x 100mm hex head bolt & the 2 hoses by jubilee clips.if it's the engine block side cover next to the injection pump you need 1 x gasket ERR2026 [Not all 200Tdi have this breather cover fitted - it was deleted on later engines & the cyclonic breather above was used on it's own] Thanks Ralph, You always come up with the goods. I decided to clean it anyway, and as it turns out there was no gasket there! No wonder there was plenty of oil around. Cheers, Paul. Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 14, 2006 Author Share Posted November 14, 2006 Problem is, I can't find LLO100000 listed anywhere. Maybe I'm not dealing with the right companies? I have tried Paddocks and Rimmer, but no success. Quote Link to comment Share on other sites More sharing options...
chadler Posted November 14, 2006 Share Posted November 14, 2006 Problem is, I can't find LLO100000 listed anywhere. Maybe I'm not dealing with the right companies? I have tried Paddocks and Rimmer, but no success. type it into google.... Quote Link to comment Share on other sites More sharing options...
western Posted November 14, 2006 Share Posted November 14, 2006 LLO100000 is the only number for that O ring seal I have, it should be possible to obtain a similar seal to suit provided it's oil & heat resistant, it's not listed in my paper LR parts cat, only on EPC so it maybe a main dealer only, normally I think it would come pre-fitted to a new cyclonic breather. I can't find it on Craddocks site either, looks like a trip to the LR main dealer parts dept. Quote Link to comment Share on other sites More sharing options...
western Posted November 14, 2006 Share Posted November 14, 2006 type it into google.... Found it LLO100000 'O' ring seal never thought of using Google to find it Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 14, 2006 Author Share Posted November 14, 2006 Found it LLO100000 'O' ring seal never thought of using Google to find it Thanks Ralph, I searched using aol powered by google, but it didn't produce any results. Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 20, 2006 Author Share Posted November 20, 2006 Thanks Ralph, I have now ordered the o ring. Cost twice as much in P&P to the part cost. Where would you say you get the best P&P prices for such parts? Quote Link to comment Share on other sites More sharing options...
western Posted November 20, 2006 Share Posted November 20, 2006 For where you are currently, any parts from UK will cost more, I don't know who would have the best p+p prices, I've got a tame LR parts place at the other end of town to me. Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 20, 2006 Author Share Posted November 20, 2006 For where you are currently, any parts from UK will cost more, I don't know who would have the best p+p prices, I've got a tame LR parts place at the other end of town to me. Actually it costs no more to post here. We are on BFPO, so goes at UK P&P prices. The address doesn't indicate that we are abroad for security reasons. Quote Link to comment Share on other sites More sharing options...
western Posted November 20, 2006 Share Posted November 20, 2006 That helps with postage costs then, My parts supplier doesn't have a website but has e.mail & as far as I know will send to most locations, I'll PM his e.mail address to you. Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 20, 2006 Author Share Posted November 20, 2006 That helps with postage costs then, My parts supplier doesn't have a website but has e.mail & as far as I know will send to most locations, I'll PM his e.mail address to you. Cheers Ralph Quote Link to comment Share on other sites More sharing options...
Paul64 Posted November 27, 2006 Author Share Posted November 27, 2006 If it's the round black canister [cyclonic breather] bolted to the right of the cylinder head above the vacuum pump, you need 1 x 'O' ring seal part number LLO100000, the canister is held by 1 x 100mm hex head bolt & the 2 hoses by jubilee clips.if it's the engine block side cover next to the injection pump you need 1 x gasket ERR2026 [Not all 200Tdi have this breather cover fitted - it was deleted on later engines & the cyclonic breather above was used on it's own] 'O' ring arrived today Ralph from Rimmer Bros, and I fitted it this evening. Rimmer seems like a good company, with no problems delivering to BFPO. Even have a postal tracking service which is quite a nice feature. Thanks again, Paul. Quote Link to comment Share on other sites More sharing options...
western Posted November 27, 2006 Share Posted November 27, 2006 happy to help Quote Link to comment Share on other sites More sharing options...
Mean Green Posted November 28, 2006 Share Posted November 28, 2006 (edited) Just as an aside .. try this website.. for all parts. www.thepart.com It is an online stock list for LR main Stealers, it also list parts avail at indy's. I find it useful for comparing prices of genuine vs other. edited to make link a clicky one Edited November 28, 2006 by western Quote Link to comment Share on other sites More sharing options...
