neil3728 Posted August 17, 2015 Share Posted August 17, 2015 I have a Landrover 110 fitted with a desco 200tdi engine. I have a small leak on the cooling with is coming form the bottom rad hose where it joins the engine. Is there a difference between the disco and the defender engines when ordering the hose and if so which one is best for my car. Want to order the right one to save the Mrs having a go at my again. Many thanks Neil Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 17, 2015 Share Posted August 17, 2015 It's been a while since I looked at a defender version but I thought they were different, what does the one you've got look like? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 17, 2015 Share Posted August 17, 2015 Discovery water pumps face the floor to accept the bottom hose, Defender points at about 8oclock. With it being a conversion chances are you have a bodged hose to make it fit. If you can post a pic we can probably help a bit more. Quote Link to comment Share on other sites More sharing options...
neil3728 Posted August 17, 2015 Author Share Posted August 17, 2015 Mine points to the ground as that's where it's leaking from the jubilee clip seems to have given up the ghost. I'll try to get some picture tonight. Quote Link to comment Share on other sites More sharing options...
western Posted August 17, 2015 Share Posted August 17, 2015 item 17 in http://www.allbrit.de/UNI.cfm?PAGE=807936&SPRACHE=EN Discovery 200tdi bottom hose item 3 in http://www.allbrit.de/UNI.cfm?PAGE=760451&SPRACHE=EN Defender 200tdi bottom hose Quote Link to comment Share on other sites More sharing options...
Lewis Posted August 18, 2015 Share Posted August 18, 2015 Unless your engine is mounted well forward or your radiator well back the disco hose will be of no use as it will be too short. I would suggest, as others have said, that the hose you have fitted in likely to be made up of two or more different hoses cut and shut with a joiner. If you post a couple of pics we can try to identify it If you want a one price hose Steve Parker Land Rovers so a set of cooling hoses which are custom made to suit a disco engine in defender. The only caveat is that you cannot use a viscous fan with them https://www.steveparkers.com/product/spck239-bottom-radiator-hose-for-200-tdi-discovery-into-90-or-110/ Quote Link to comment Share on other sites More sharing options...
neil3728 Posted August 18, 2015 Author Share Posted August 18, 2015 Just talked to my friend who I bought the car from , he has confirmed the old pipe was from Steve Parker, hence why I have no viscous fan. Quote Link to comment Share on other sites More sharing options...
