Wattle Posted November 16, 2006 Share Posted November 16, 2006 I have just uploaded the S19 file using Hyperterm and now nothing is working when connected up to the stim. Its probably something that I have done wrong . Any ideas would be gratefully received. Thanks Phil Watson Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted November 16, 2006 Share Posted November 16, 2006 Paging Mr Fridgefreezer to come to reception!! Quote Link to comment Share on other sites More sharing options...
v8bertha Posted November 16, 2006 Share Posted November 16, 2006 Have sent him a text, hopefully he'll be along shortly Quote Link to comment Share on other sites More sharing options...
Wattle Posted November 16, 2006 Author Share Posted November 16, 2006 Excellant Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 16, 2006 Share Posted November 16, 2006 Sheesh, now I get summoned by text message! Good job no-one knows my pager number... Did you take the boot jumper off after you'd flashed it? Not that I've ever forgotten it of course... Also check there's no conflicts in config, if you have uploaded the "extra" code it will do nothing if you set it up wrong, connect the ECU to the stim & run hyperterm again and it might chuck out an error message when you power it up. Failing that, flash it again Quote Link to comment Share on other sites More sharing options...
Wattle Posted November 16, 2006 Author Share Posted November 16, 2006 Sheesh, now I get summoned by text message! Good job no-one knows my pager number...Did you take the boot jumper off after you'd flashed it? Not that I've ever forgotten it of course... Also check there's no conflicts in config, if you have uploaded the "extra" code it will do nothing if you set it up wrong, connect the ECU to the stim & run hyperterm again and it might chuck out an error message when you power it up. Failing that, flash it again I have just flashed it again, and its know working again. Thanks for the help, its much appreciated. Phil Watson Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 16, 2006 Share Posted November 16, 2006 That reminds me - if the battery / supply voltage is too low it won't flash properly. MegaTune and the auto flash program will warn you of this, Hyperterm won't as far as I'm aware. Quote Link to comment Share on other sites More sharing options...
