Front/Rear Brake distribution valve
WesBrooks
Can anyone point me to a good description of what this valve is? I think it is dropping the brake pressure to the rear wheels to balance the braking. Is this s straight proportional drop? If I move it do I need to keep the orientation of the unit the same?
Thanks,
Wes.
As Western said , it prevents rear brake lock up by limiting the hydraulic pressure to the rear brakes - hydraulics having a nasty habit of the fluid going to the furthest pint in the system first and building up pressure from the rear to the front.
You can remove it and replace it with an adjustable unit, as I have on my Disco, so that you can "dial" up the amount of rear braking you want but otherwise if its not working, replace it, don't try to adjust it yourself as this is done on a rig and the adjustment then sealed.
In regard to the adjustable brake limiting valve, on flat fast dirt roads I like the rears to come "on" before the front to cause the rear to slide out and assist in fast "turn-in" into corners, on bitumen this would be possibly fatal.
That's the part.
Any one got any idea if this is dynamic or fixed proportioning of the pressure and is orientation critical?
I've got to remake my brake lines due to heavy corrosion and the inner wings maybe completely different to stock. I'd like to not have to worry about keeping the orientation the same. However, if it lowers back brake pressure more as the truck pitches forward under braking then I'll need to keep the orientation fixed.
