cackshifter Posted April 5, 2016 Share Posted April 5, 2016 Hi, I have a 300tdi 90, and it has stood for a couple of weeks while I have been working on the brakes. So I thought tonight when I got it back on its wheels I had better start it to freshen the battery and move it slightly to release the wheel chocks - which I did. It started readily but idled very slowly so I gave it a bit of accelerator and not a lot happened for a few seconds, then it gradually picked up revs. Once it had got a bit of speed up it seemed fine, it would readily rev, and after idling it was much more responsive. It has just recently had a new turbo, piping, intercooler and new filters, and when changing the diesel filter I pumped it full by hand with the lift pump no problem. Presumably it has to be a fuel problem, maybe a blockage or faulty lift pump, but has anyone got any bright ideas as to where to look first? Quote Link to comment Share on other sites More sharing options...
dave88sw Posted April 6, 2016 Share Posted April 6, 2016 Perhaps the fuel had drained back a bit from standing. Started on what was left in the injector pump but then struggled to pull enough through for a few seconds. What do the return lines look like (the rubber pipes between the injectors)? Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 6, 2016 Author Share Posted April 6, 2016 You are thinking there may be an air leak into the leak off piping? Yes, could be, the pipes look a bit old though nothing obvious, presumably that would do it? Quote Link to comment Share on other sites More sharing options...
Maverik Posted April 6, 2016 Share Posted April 6, 2016 Is the fuel filter bled properly? - I usually get the engine going then open the bleed screw and let the engine do the rest, when bubbles stop flowing I tighten it up. 1 Quote Link to comment Share on other sites More sharing options...
cackshifter Posted April 6, 2016 Author Share Posted April 6, 2016 Thanks for that suggestion, I'll give it a whirl. Quote Link to comment Share on other sites More sharing options...
