defender dinky Posted April 20, 2016 Share Posted April 20, 2016 hi, discovery engine into defender I am at the stage connecting glow plugs up but there wasn't any loom with the engine so starting from scratch, I am copying a lot from my 90 with the same conversion all I can see is one brown/red trace coming from glow plugs back into bulkhead it goes to ignition not sure if glow plug even work no lights on dash to state this, so has anyone got a wiring diagram for glow plugs, also on starter motor I have four brown wires coming off two of which go to alternator other two go threw bulkhead why is there two going to alternator, dd Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 21, 2016 Share Posted April 21, 2016 There's a wiring diagram in the Haynes manual. Well really any workshop manual will have the diagram because most of the relays are the same but different. My Range Rover that I converted to a 200Tdi had an Astra relay fitted. HTH Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted April 21, 2016 Share Posted April 21, 2016 All the wiring diagrams are in the RAVE CD. You can download it here. http://www.overlandbirds.com/land-rover-files.html Quote Link to comment Share on other sites More sharing options...
defender dinky Posted April 21, 2016 Author Share Posted April 21, 2016 found a plug with all the right wires in which I think fits into a relay(no relay there) but the thick yellow/black has been cut off and also the thick brown wire seems to have gone to passenger side with headlight loom but has also been cut off y/b I presume goes to heater plugs where should the brown wire go Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 21, 2016 Share Posted April 21, 2016 First of all, this Lucas colour diagram may help you .http://www.expeditionlandrover.info/Lucaswirecode.htm I suspect the Brown will come, or go to, the battery or the starter motor. The Black/ Yellow to the heater plugs. You can check bu using a fused link and a test light. Quote Link to comment Share on other sites More sharing options...
western Posted April 21, 2016 Share Posted April 21, 2016 thick brown/red trace was from ign switch to glowplugs on my 110 ex 2.5 TD engine, when my 200tdi was fitted complete with glowplug relay the thick brown/red wire is redundant. Quote Link to comment Share on other sites More sharing options...
