petrolhead63 Posted June 21, 2016 Share Posted June 21, 2016 I got a face full of coolant today when I diagnosed the coolant rail pipe as clapped putting my screwdriver through it ? any tips replacing? Also the plastic under engine guard.....all undone, clearly does not slide out without removal of parts. Can anybody enlighten me as to what I can get away with. I'm temped to saw it in two and refit making joining plates to make future work easier! it seems daft. Quote Link to comment Share on other sites More sharing options...
IanS Posted June 21, 2016 Share Posted June 21, 2016 Mine's never had that plate since I bought it 7 years ago and I haven't noticed any problems....... Quote Link to comment Share on other sites More sharing options...
sierrafery Posted June 21, 2016 Share Posted June 21, 2016 to remove the guard you have to use a jack and lift the chassis iirc from the crossmeber untill you can pull it out backwards.... no need to undo anything Quote Link to comment Share on other sites More sharing options...
petrolhead63 Posted June 21, 2016 Author Share Posted June 21, 2016 Thanks, its off.....could not lift it enough to pull back clear of axle even with big jack. I dropped steering damper and steering rod which took 5 mins and also had to lift chassis a little to clear it forward. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted June 21, 2016 Share Posted June 21, 2016 I remember that when i removed mine i didnt undo anything, mine is a LHD manual, maybe there is some difference Quote Link to comment Share on other sites More sharing options...
Shackleton Posted June 21, 2016 Share Posted June 21, 2016 Any chance of a photo of the tray, I'm not sure if mine has one or not? Quote Link to comment Share on other sites More sharing options...
sierrafery Posted June 22, 2016 Share Posted June 22, 2016 You can see in this link http://www.allbrit.de/UNI.cfm?PAGE=820436&SPRACHE=EN what should be there Quote Link to comment Share on other sites More sharing options...
Shackleton Posted June 22, 2016 Share Posted June 22, 2016 Oh! yeah no I don't have that, or the other one - a gearbox cover? Quote Link to comment Share on other sites More sharing options...
