IanT90 Posted July 7, 2016 Share Posted July 7, 2016 Brake pipe problem resolved thankfully. Apart from fabrication of a new pipe for the caliper which is 90% done, with finish when caliper is in position. However, just finished stripping and preparing the O/S for re-assembly. I took the new brake disc out the box and noticed it said RHS (Not vented but drilled and grooved solid disc, hence my question). Logic tells me its correct but lack of sleep over the last week has taken it's toll and just wanted some confirmation ? O/S is RHS N/S is LHS I always remember it as sitting in the drivers seat O/S right ? May seem like a daft question but once there is that niggling doubt in your mind you become more uncertain, specially when your mentally drained after 6 x 12 hour night shifts and working on Land Rover too. Ian Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted July 7, 2016 Share Posted July 7, 2016 Sitting in the drivers seat, the off side is the right side (off side from kerb) and near side is the left (side closest to the kerb) - so you are correct (right!!!!). Toby 1 Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted July 7, 2016 Share Posted July 7, 2016 Ian, generally the rhs is the off side. normally seen when sitting in the drivers seat. i've often been puzzled by this, especially when looking under the bonnet. LHS is the near side. Quote Link to comment Share on other sites More sharing options...
IanT90 Posted July 7, 2016 Author Share Posted July 7, 2016 Thanks guy's much appreciated, the last logical part of my brain that's still functioning correctly told me I was right but just needed some reassurance. Already replaced the N/S disc and don't remember seeing a LHS label. Or if I did I just went ahead knowing LHS was the N/S. As I said previously lack of sleep plays tricks on your mind and you start to doubt yourself. Thanks again much appreciated I can crack on now. Regards Ian Quote Link to comment Share on other sites More sharing options...
western Posted July 7, 2016 Share Posted July 7, 2016 on a Right hand drive vehicle, the subject vehicles --- right = off side or drivers side. left = near side or passenger side regardless of where you are sitting or viewing the vehicle from, this also applies to any boats/ships or any aircraft regardless of size, where Left = Port & Right = Starboard Quote Link to comment Share on other sites More sharing options...
