Cornish Rattler Posted September 21, 2016 Share Posted September 21, 2016 Hi guys whilst I have been out and about recently I can hear and feel a knock coming from the back end I have just replaced the rear radius arm bushes as I damaged one whilst replacing them when doing the chassis swap in February this year aswell as fitting a full Bearmach poly bush kit with new BP +2" springs all round, +2" front shocks and +5" rear shocks, the noise has just suddenly happen'd in the last few weeks and thought replacing the rear radius arm bushes would cure it but hasn't, I haven't measured it but the 90 still looks like it has the same gap between the tyres and the arches but wondering if the rear springs could have slackend off and need wear pads between the rear springs and cups what do u think Quote Link to comment Share on other sites More sharing options...
western Posted September 22, 2016 Share Posted September 22, 2016 check the A frame to top of rear axle ball joint & the A frame arms to chassis mounts. springs can't 'slacken off' no need for 'wear pads' between spring & chassis mount, also check rear damper fixings are not busted, Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 22, 2016 Share Posted September 22, 2016 What Ralph said pretty much. Mo Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted September 22, 2016 Author Share Posted September 22, 2016 Cheers guys I will check all the back end out on Saturday and let I no what I find Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted September 24, 2016 Author Share Posted September 24, 2016 Spent most of the day hunting round for some grease cartridges so will give the landy a good greasing whilst I am checking stuff which will be Monday now Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted September 26, 2016 Author Share Posted September 26, 2016 Sorted I gave the landy a good greasing this morning before the rain started inc the rear ball joint, think I may have missed it the last time I greased the 90 up or I didn't pump enough grease in but it seems ok now Quote Link to comment Share on other sites More sharing options...
