Water in boot storage box
#1
Posted 19 September 2006 - 07:38 PM
#3
Posted 19 September 2006 - 09:44 PM
Just my 2p you understand
Oh and the other way you can get water in the boot is to reconnect the battery, forget that this makes the window go down and then park it outside in the P*ssn rain for a week. Don't bother asking how I know THAT
#4
Posted 20 September 2006 - 05:41 PM
First is condensation, usually on the lid, but will spread mould along the carpet if it is left lone enough.
Cure is to air it out and may be drill one or two holes in the lid. Job done.
Second is a leaking door seal. More common on older models as a different part number was used later. This leads to significant amounts of water in the cubby after rain. I have this on one of mine. I regularly mop out but will have to bite the bullet and get around to fitting the later door seal at some point. I gather it is a bit of a pain of a job, probably the reason why many haven't been done by the dealers on recall.
Cheers
Blippie
#5
Posted 24 September 2006 - 11:17 PM
how do you know that?
#6
Posted 29 September 2006 - 08:33 AM
Most early ones sufferd with this but some the dealer sorted in there early days.
It strated from the fixings from the gutter above the back window a bead of mastic normaly sorted that out
stopped it from sloshing around.
Dents are like scratches with a better story
#7
Posted 29 September 2006 - 09:56 AM
Cheers
Blippie
#8
Posted 02 October 2006 - 10:14 AM
#9
Posted 03 October 2006 - 02:37 PM
We each have a pair of "mirror spiders" that cast webs over the wing mirrors but hide away inside when you are driving.
Thing is, I've just swapped the mirrors on the Camel for the later 2001MY folding mirrors. It didn't occur to me that I have removed the mirror spiders.
I wonder if they are still inside the old ones. Perhaps I should transplant them too.
Cheerio
Blippie
#10
Posted 03 October 2006 - 05:19 PM
#11
Posted 05 October 2006 - 12:54 PM
#12
Posted 05 April 2007 - 05:41 PM
For info, the part numbers are:
Side trim clips = DCE 100560
Top trim clips = DYC 101470
Hope this helps.
#13
Posted 05 April 2007 - 05:59 PM
This brings back memorys of our 03 plate Freelander, we had both water in the cubby box and mirror spiders - I also fondly remember the windscreen wipers packing up on wet drive from Aberdeen to Glasgow
The water in the cubby was due to condesation, enhanced by the rubber floor mat. The spiders, we had to pay Land Rover extra for. I solved the water problem by moving to Oman and buying a 1985 110. Needless to say owning an early 110, water is th least of my worries.
#14
Posted 01 May 2007 - 05:39 PM
Ah, well, I never know whether to specify pattern, OEM or Genuine Part spiders.
Cheers
Blippie
