mcc1979ian Posted May 27, 2015 Share Posted May 27, 2015 Evenin. Just wondering what grade and size bolts you guys use to mount a recovery point through the chassis rear crossmember, cheers Quote Link to comment Share on other sites More sharing options...
Lewis Posted May 27, 2015 Share Posted May 27, 2015 My nato hook is held on with 4 8.8 M12 bolts Quote Link to comment Share on other sites More sharing options...
western Posted May 27, 2015 Share Posted May 27, 2015 8.8HT steel nothing less will cope, 10.9HT if you can source some are even better, plus spreader plate on inside at the minimum. Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 28, 2015 Share Posted May 28, 2015 As Ralph says, I'd probably say the spreader plate is the key thing, bolt quality doesn't matter if the bolts get pulled through the relatively thin plate. Using a relatively standard 8.8 grade steel or A2/A4-80 grade Stainless bolt or equivalent would do you - also making sure they torqued up correctly too. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted May 28, 2015 Share Posted May 28, 2015 As above, M12 8.8 is standard Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted May 28, 2015 Author Share Posted May 28, 2015 Excellent, cheers Quote Link to comment Share on other sites More sharing options...
