foxminer Posted May 22, 2007 Share Posted May 22, 2007 Hello all, i,m thinking of fitting a EGR blanking plate to my TD5 whilst i have the head off for a new gasket. I have read a few subjects on this and it does have some advantages. What i`m asking is has anybody already done this to thier own disco and did it make a difference?. Any answers will be appreciated. Foxminer. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 22, 2007 Share Posted May 22, 2007 If the valve is not already jammed open you can blank off the vacuum pipes to the modulator unit with a couple of blind pop rivets and cable ties which is a damn sight cheaper! However if the valve is already jammed open it won't work. Quote Link to comment Share on other sites More sharing options...
Hugowessels Posted May 23, 2007 Share Posted May 23, 2007 On mine the EGR valve burnt through? I am not sure if the terminology is correct but the exhaust gas escaped and burnt through one of the brake pipes, resulting in no brakes. Fortunately we heard the noice and stopped in time apparently the vehicle can also burn down due to the hot gas escaping into the engine bay. This is enough reason for me to blank it of, you can lose the whole vehicle. Apparently it can also increase performance and reduce fuel consumption? Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted May 23, 2007 Share Posted May 23, 2007 I have done this on my 300TDI and it definately smokes less than it did and more importantly is not cokeing up the inlet tract with a marmite like substance. Can't really say that it had a huge effect on the way the truck goes but I sorted several things out at the same time which all made a difference. HTH Pete. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 23, 2007 Share Posted May 23, 2007 If you blank it off properly, then the exhaust gases are contained within the exhaust sytem, so there is no danger. Les. Quote Link to comment Share on other sites More sharing options...
tuko Posted May 24, 2007 Share Posted May 24, 2007 I installed the EGR blanking plate, removed & replaced the top induction hose with a LR original hose and I'm pleased with the result. I've been told don't use a sh!tpart top hose, as they tend to collapse very quickly. Throttle response has improved, less smoke and fuel economy has improved, with the highway miles that we do daily. Todd. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted May 26, 2007 Share Posted May 26, 2007 We had a TD5 where the coupling from the stainless pipe to the alloy EGR valve burnt through. This made a mess of the plastic engine cover; luckily nothing burnt through or caught fire. So now we fit blanking plates to the manifold and throw the pipes away. Our latest is to also throw the EGR valve away and fit a fabricated steel pipe in its place. The plate with the four holes is laser cut, and welded to a pipe of the right size. We can fit these to the latest TD5s which keep the EGR valve even though it doesn't work. It might help a bit for the top-end power to get rid of the obstruction inside the EGR valve. Quote Link to comment Share on other sites More sharing options...
foxminer Posted May 26, 2007 Author Share Posted May 26, 2007 We had a TD5 where the coupling from the stainless pipe to the alloy EGR valve burnt through. This made a mess of the plastic engine cover; luckily nothing burnt through or caught fire. So now we fit blanking plates to the manifold and throw the pipes away. Our latest is to also throw the EGR valve away and fit a fabricated steel pipe in its place. The plate with the four holes is laser cut, and welded to a pipe of the right size. We can fit these to the latest TD5s which keep the EGR valve even though it doesn't work. It might help a bit for the top-end power to get rid of the obstruction inside the EGR valve. Is it neccasary to alter pipes or can i just put the blanking plate between the manifold and pipe going to the valve?. It came complete with plate, new gasket and new allen bolts. Foxminer Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 26, 2007 Share Posted May 26, 2007 It sounds like the kit you have is for completely removing the EGR valve. The gasket and plate go over the hole on the top of the exhaust manifold. Les. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted May 26, 2007 Share Posted May 26, 2007 Correct. We blank off the manifold AND remove the EGR valve itself. Looks nice, no rubbish. We also take off the redundant heater coolant pipe that LR fitted to late-model engines although it was not connected to anything. Funny bunch of engineers they have there. Quote Link to comment Share on other sites More sharing options...
tio Posted May 29, 2007 Share Posted May 29, 2007 for mine i used a bearing from a shimano bottom bracket from a bike, i would be careful about any claim's about performance upgrade,s on my td5 it felt like giving an asthmatic an inhaler and now it doesnt feel like your pushing it on to maintain 70-80 mph a bit like overdrive but it does feel less torqey low down but just when moving away once it's rolling it's superb, once out of warranty it will be consigned to the skip after being beaten senceless by a big hammer, despiseable thing !!!!!! Quote Link to comment Share on other sites More sharing options...
lynall Posted May 30, 2007 Share Posted May 30, 2007 This is my 4th disco and the third that i have removed the egr completeley, cant say i noticed any difference but as they were all chipped/tuned any minor differences would not be as notable as on a std car. My current motor is a TD5 and i fitted the complete EGR removal kit from TD5alive, easy to fit and as alrady said removes a load of carp fom the engine bay. Lynall Quote Link to comment Share on other sites More sharing options...
