NicTheOrange90 Posted June 20, 2006 Share Posted June 20, 2006 I have just made a prototype spare wheel carrier for the Disco's larger diameter spare wheel. I had intended in modifying the Disco mount, but with the wiper in the way, decided on an adaptor plate. I had a 110 spare wheel mount in the garage so made up a wooden former that had the three holes from the Disco, and immediately above the three for the 110 door mount. I now want to make a metal plate version before I take this out on the road, so if anyone knows where I can get such a beasty made let me know. Alternatively, if anyone has any better ideas, please advise... I will probably crop the 110 mount at the bottom so the spare sits a bit lower, and does not obscure the rear window so much, but the clearance between the bumper and the wheel is not now a problem... side view side view no wheel All pictures Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 20, 2006 Share Posted June 20, 2006 I believe Devon 4x4 do a raised spare wheel carrier for Discoverys for up to 35" spare wheels Quote Link to comment Share on other sites More sharing options...
Kev Baldwin Posted June 21, 2006 Share Posted June 21, 2006 Indeed, Devon do a HD carrier that'll take a 36in tyre. Couple of US companies also do the same. Your design will put a helluva lot of stress on the back door. Quote Link to comment Share on other sites More sharing options...
Porny Posted June 21, 2006 Share Posted June 21, 2006 The Devon one: http://www.devon4x4.com/shop.php?mode=prod...at=24&subcat=33 In all honesty, probably cheaper than getting some one to make it for you. Ian Quote Link to comment Share on other sites More sharing options...
cols110 Posted June 21, 2006 Share Posted June 21, 2006 Good concept, but there is more leverage with a bigger wheel now, so I`d be worried about the back door being able to support it. Quote Link to comment Share on other sites More sharing options...
Andy Posted June 21, 2006 Share Posted June 21, 2006 this is probably a really daft question, but as the design shown here & the devon4x4 mount use the original bolt holes. why would this design put more stress on the door? as far as i can see the extra load is getting transfered to exactly the same place on the door. Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted June 21, 2006 Author Share Posted June 21, 2006 The Devon one:http://www.devon4x4.com/shop.php?mode=prod...at=24&subcat=33 In all honesty, probably cheaper than getting some one to make it for you. Ian With VAT and postage the D44 one comes to £70.00. I agree that this is a more professional looking device, and may be the cheaper option, if I include the time already spent, then getting someone to cut the 10mm steel plate, and me to drill the holes and then paint it etc. Hmm.. Need to think about this one Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted June 23, 2006 Author Share Posted June 23, 2006 Ordered the D4 today ! it looks a lot nicer than my one ! Not that I have a spare yet, been waiting 3 weeks from Bronco4x4, they say it might be another 3! Quote Link to comment Share on other sites More sharing options...
Budgie Posted June 23, 2006 Share Posted June 23, 2006 this is probably a really daft question, but as the design shown here & the devon4x4 mount use the original bolt holes. why would this design put more stress on the door? as far as i can see the extra load is getting transfered to exactly the same place on the door. It's to do with the leaverage Andy. The wheel on the D44 carrier is basicly in the same place as the original, only a 2-3" higher. The D44 carrier also sits flush to the rear door all the way up and is of a stronger build. NicTheOrange90's mod raises the wheel quite a bit above that of the original and, more importantly, extends the location of the spare wheel rearwards. Add to this the extra weight of the larger tyre and this rearward extention will have the effect of putting the top securing bolts, through the door frame, under stress from a pivoting motion especialy when offroad. As an example, if you look at the side view of NicTheOranges90's one and compare it to the gap on mine with a 33x12.5R15 tyre on the D44 carrier you'll see what I mean. I hope that, sort of, explains it. NicTheOrange90, Please don't get me wrong here, I'm not 'dissing' your work. I think it's a great use of the materials available to come to a solution. All I'm doing here is trying to answer Andy's question. You'll be pleased with the D44 carrier though, it's a good bit of kit! Quote Link to comment Share on other sites More sharing options...
Andy Posted June 25, 2006 Share Posted June 25, 2006 ahh cheers budgie, obvious when you think about it really. i hadnt clicked how the D4 one didnt raise the wheel as much. Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted July 12, 2006 Author Share Posted July 12, 2006 D44 spare wheel mount OK, so Devon 4x4's is a little more snazzy than mine ! I put the CB Aerial mount on as well (great idea from this forum) and used a wing mirror mount to attach the thing to the D44 mount. Also put a new front winch and bumper on - just need to decide on where to fit the front registration plate ! New front bumper #1 New front bumper #2 Quote Link to comment Share on other sites More sharing options...
Budgie Posted July 12, 2006 Share Posted July 12, 2006 Looking good. On my BRB bumper the Hi-lift points are under the bumper so I managed to get the reg' plate on the front of the bumper. Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted July 13, 2006 Author Share Posted July 13, 2006 Where did you get the A bar from? Looks nice Quote Link to comment Share on other sites More sharing options...
Andy Posted July 13, 2006 Share Posted July 13, 2006 sticky plate on the bonnet if you can find somewhere with one left. ive just had a sticky one for over a year now, never been stopped & passed two MOTs. Quote Link to comment Share on other sites More sharing options...
Budgie Posted July 13, 2006 Share Posted July 13, 2006 Where did you get the A bar from?Looks nice It's a Defender A-bar that bolts to the top of the bumper. A slightly better shot for you. Quote Link to comment Share on other sites More sharing options...
