Trevorevans Posted May 1, 2011 Share Posted May 1, 2011 I've been told that the rubber 'doughnut' on the rear prop shaft of the 300Tdi is a common failure made worse by lifting the suspension and general off road use, I've also been told that the cure is to do away with it by fitting the rear prop from a 200Tdi, is this information correct? What are your opinions/experience? Quote Link to comment Share on other sites More sharing options...
hanlon Posted May 1, 2011 Share Posted May 1, 2011 just change the doughnut easy to do just 6 nuts and bolts Quote Link to comment Share on other sites More sharing options...
Escape Posted May 2, 2011 Share Posted May 2, 2011 I've been told that the rubber 'doughnut' on the rear prop shaft of the 300Tdi is a common failure made worse by lifting the suspension and general off road use, I've also been told that the cure is to do away with it by fitting the rear prop from a 200Tdi, is this information correct? What are your opinions/experience? This is correct. When lifting the suspension, the angle of the rear prop changes as well, and the rubber has a hard time handling the stress. Fitting a proper UJ is the best solution, but remember you need a different (4 bolt) diff flange as well. Changing the doughnut itself is easy, but the bush inside of the prop that stabilises the doughnut also wears, and can be a PITA to remove. LR/OEM kits include both doughnut and inner bush, cheap aftermarket kits in blue boxes only have the doughnut. Quote Link to comment Share on other sites More sharing options...
sutty_32 Posted May 2, 2011 Share Posted May 2, 2011 Fitting a prop has been the best solution for me, doesn't wear as quick and saves money in the long run Quote Link to comment Share on other sites More sharing options...
sutty_32 Posted May 2, 2011 Share Posted May 2, 2011 by prop I mean a 200tdi prop, with a UJ at both ends Quote Link to comment Share on other sites More sharing options...
ChrisW70 Posted May 2, 2011 Share Posted May 2, 2011 With a 2" lift as mine has be prepared to typically change the doughnut every six months if you stay with it, when my rear diff packed up I swapped it out with a diff off a disco front axle (already got the 4 bolt flange) and fitted a 200 prop with new UJs, that was about 4 or 5 years ago and other than regular greasing I haven't had to change a UJ on the rear yet... Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted May 3, 2011 Share Posted May 3, 2011 If you do the doughnut then you need to do the support busg too, otherwise the doughnut can go again very quickly. The 2 parts don't seem to like a big lift though. Quote Link to comment Share on other sites More sharing options...
